[pgrouting-dev] Issue 16 applied to "master" branch but not part of "sew-devel-2_0"
Daniel Kastl daniel at georepublic.de
Sat May 4 07:21:27 PDT 2013
Hi Steve,
I checked if I could delete the "issue16" branch as it was merged into
"master" already.
But then I looked at "sew-devel-2_0" branch and only found the previous
version.
The ticket: https://github.com/pgRouting/pgrouting/issues/16
The changes:
https://github.com/pgRouting/pgrouting/commit/a8a01f839f98b286d122a4237c6abd44d21729ad
"master":
https://github.com/pgRouting/pgrouting/blob/master/core/sql/routing_topology.sql
"sew-devel-2_0":
https://github.com/pgRouting/pgrouting/blob/sew-devel-2_0/src/common/sql/pgrouting_topology.sql
I thought it would be OK to prepend the schema name to the table name.
If this is not possible for pgr_assign_vertex_id, then Kishore's changes
would be good.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130504/c55afa70/attachment.html>
More information about the pgrouting-dev mailing list
