[pgrouting-dev] Documentation update
Daniel Kastl daniel at georepublic.de
Sun May 5 08:37:01 PDT 2013
I have added a bit of documentation to "sew-devel-2_0" branch.
And I started using a theme named "Cloud Sphinx Theme" (
http://pythonhosted.org/cloud_sptheme/), because I like it and got tired of
the default theme ;-)
To be able to compile with documentation it's now necessary to install the
theme as well (http://pythonhosted.org/cloud_sptheme/install.html), which
is easy if Sphinx is installed already.
I updated the Readme accordingly:
https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0#compilation
I started adding documentation for
   - Dijkstra
   - Return types
For the functions I'm following
https://docs.google.com/spreadsheet/ccc?key=0AiIg1pkkh_MRdGQzOEhyaXlndkN3eHdGNkpyQ0pMZFE&usp=sharing
I found it a bit inconvenient to have Dijkstra "core" and "wrapper"
functions documented together, so I split it into two pages even if the
function name is the same.
I tried to follow the documentation of PostGIS, but this only worked partly.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130506/d308a184/attachment.html>
More information about the pgrouting-dev mailing list
