[pgrouting-dev] Bidirectional Integration bug
Daniel Kastl daniel at georepublic.de
Mon May 6 22:40:32 PDT 2013
Hi Razequl,
The currently used branch is named "sew-devel-2_0" (we're planning to
rename it to "develop" some time).
You find all the necessary steps to compile explained on the Github readme:
https://github.com/pgrouting/pgrouting/tree/sew-devel-2_0
If you want to compile with support for "Driving Distance", then you need
to have CGAL libraries as dependency. GAUL dependency is gone.
Daniel
On Tue, May 7, 2013 at 2:35 PM, Razequl Islam <ziboncsedu at gmail.com> wrote:
> Hi Steve,
> I also want to have a look at the possible problem. I am trying to set up
> the environment on my machine. I have the previous version. What do I need
> to do to get 2.0 working? Should I set up the environment from the scratch
> or should an update will do. Please let me know how I should proceed. I can
> also do the debugging once I have the environment in place.
> Thanks.
> - Razequl
> On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge <
> woodbri at swoodbridge.com> wrote:
>> Hi Razequl,
>> I have been trying to integrate your bidirectional shortest path code. I
>> have merged the code into my pgrouting branch "sew-devel-2_0", but it is
>> crashing the back-end with a segv.
>> If you have time and want to look into this that would be great as I
>> would like to get this code working in 2.0.
>> I'm not sure if I found a bug in your code or I broke something when I
>> merged it, or for that matter that I even merged the correct code :)
>> because you sent email indicating that you fixed stuff. I merged the code
>> from master at https://github.com/zibon/**pgrouting<https://github.com/zibon/pgrouting>
>> I also ran into an issue that when I merged you code into the code
>> library, that the trsp broke, then take you code out and it works again. I
>> assume that there is some kind of function name or global initialization
>> issue. This does not seem to be an issue for trsp now that the bi-dir code
>> is in a separate library.
>> This might give you a chance to get your development/test/debug
>> environment setup and to familiarize yourself with the new source code
>> layout.
>> Let me know if you have time and I'll help point the way. If you are tied
>> up with class work, etc that clearly takes priority.
>> Thanks,
>>   -Steve
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130507/3875e621/attachment-0001.html>
More information about the pgrouting-dev mailing list
