[pgrouting-dev] Bidirectional Integration bug
Razequl Islam ziboncsedu at gmail.com
Mon May 6 22:35:22 PDT 2013
Hi Steve,
I also want to have a look at the possible problem. I am trying to set up
the environment on my machine. I have the previous version. What do I need
to do to get 2.0 working? Should I set up the environment from the scratch
or should an update will do. Please let me know how I should proceed. I can
also do the debugging once I have the environment in place.
Thanks.
- Razequl
On Mon, May 6, 2013 at 11:32 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Hi Razequl,
> I have been trying to integrate your bidirectional shortest path code. I
> have merged the code into my pgrouting branch "sew-devel-2_0", but it is
> crashing the back-end with a segv.
> If you have time and want to look into this that would be great as I would
> like to get this code working in 2.0.
> I'm not sure if I found a bug in your code or I broke something when I
> merged it, or for that matter that I even merged the correct code :)
> because you sent email indicating that you fixed stuff. I merged the code
> from master at https://github.com/zibon/**pgrouting<https://github.com/zibon/pgrouting>
> I also ran into an issue that when I merged you code into the code
> library, that the trsp broke, then take you code out and it works again. I
> assume that there is some kind of function name or global initialization
> issue. This does not seem to be an issue for trsp now that the bi-dir code
> is in a separate library.
> This might give you a chance to get your development/test/debug
> environment setup and to familiarize yourself with the new source code
> layout.
> Let me know if you have time and I'll help point the way. If you are tied
> up with class work, etc that clearly takes priority.
> Thanks,
>   -Steve
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130507/ff31d63d/attachment.html>
More information about the pgrouting-dev mailing list
