[pgrouting-dev] Testing different versions of PostGIS with CREATE EXTENSION
Paragon Corporation lr at pcorp.us
Mon May 6 21:28:16 PDT 2013
> to test against different versions of PostGIS.
> Ok, just checked in changes:
> Usage: test-runner.pl -pgver vpg -pgisver vpgis -psql /path/to/psql
 >       -pgver vpg          - postgresql version
 >       -pgisver vpgis      - postgis version
 >       -psql /path/to/psql - optional path to psql
 >       -h                  - help
Steve,
Can you quote the vpgis version.  Version is alwaways supposted to be quoted
otherwise get the below error and everything fails regress.
LINE 1: create extension postgis  VERSION 2.1.0SVN
ERROR:  required extension "postgis" is not installed
Thanks,
Regina
More information about the pgrouting-dev mailing list
