[pgrouting-dev] git dependency in (at least) pgRouting 2.0
Daniel Kastl daniel at georepublic.de
Fri May 10 19:35:08 PDT 2013
On Sat, May 11, 2013 at 11:22 AM, Stephen Mather
<mather.stephen at gmail.com>wrote:
> Cool.  Thanks Daniel.  I figure I'm the first person to try to install it
> without git... :).  It was a fresh install though.
> Best,
> Steve
Hi Steve,
When you meant "Git is a dependency", did you refer to the cmake output
like this?
-- The C compiler identification is GNU 4.7.2
-- The CXX compiler identification is GNU 4.7.2
-- Could NOT find Git (missing:  GIT_EXECUTABLE)
This indicates, that Git isn't installed, but it doesn't prevent you from
compiling.
So it's not really a dependency, but if Git is there and the source is a
Git repository, then (as for now) it will place the version hash in the
documentation for example (in case you build the documentation)
Or do you get errors when trying to compile?
Daniel
> On Fri, May 10, 2013 at 9:47 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>> On Sat, May 11, 2013 at 12:59 AM, Stephen Mather <
>> mather.stephen at gmail.com> wrote:
>>> Here's a dependency not listed-- git itself is a dependency... .  I know
>>> this is a silly thing to point out, but it is possible on github to
>>> download a zip of the file without installing git.  Should git be added as
>>> a dependency?
>> I added a Cmake module to get some Git parameters, if available.
>> It should check if it's not a Git repository, though I didn't think about
>> it could fail if Git is not installed at all.
>> Thanks for the comment, because I didn't think about it at all.
>> I thought the Git module would be smart enough, but of course this
>> shouldn't become a build dependency.
>> Will take a look.
>> Daniel
>>> Best,
>>> Steve
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130511/3d874059/attachment.html>
More information about the pgrouting-dev mailing list
