[pgrouting-dev] git dependency in (at least) pgRouting 2.0
Stephen Mather mather.stephen at gmail.com
Fri May 10 19:38:43 PDT 2013
I definitely got errors, but I'm wondering if I got the warning, and the
errors right after for other unrelated reasons.  I'll see if I can roll
back to a state where I can replicate, but it will be Tuesday or Wednesday
of next week before I can do that.
Best,
Steve
On Fri, May 10, 2013 at 10:35 PM, Daniel Kastl <daniel at georepublic.de>wrote:
> On Sat, May 11, 2013 at 11:22 AM, Stephen Mather <mather.stephen at gmail.com
> > wrote:
>> Cool.  Thanks Daniel.  I figure I'm the first person to try to install it
>> without git... :).  It was a fresh install though.
>> Best,
>> Steve
> Hi Steve,
> When you meant "Git is a dependency", did you refer to the cmake output
> like this?
> -- The C compiler identification is GNU 4.7.2
> -- The CXX compiler identification is GNU 4.7.2
> -- Could NOT find Git (missing:  GIT_EXECUTABLE)
> This indicates, that Git isn't installed, but it doesn't prevent you from
> compiling.
> So it's not really a dependency, but if Git is there and the source is a
> Git repository, then (as for now) it will place the version hash in the
> documentation for example (in case you build the documentation)
> Or do you get errors when trying to compile?
> Daniel
>> On Fri, May 10, 2013 at 9:47 PM, Daniel Kastl <daniel at georepublic.de>wrote:
>>> On Sat, May 11, 2013 at 12:59 AM, Stephen Mather <
>>> mather.stephen at gmail.com> wrote:
>>>> Here's a dependency not listed-- git itself is a dependency... .  I
>>>> know this is a silly thing to point out, but it is possible on github to
>>>> download a zip of the file without installing git.  Should git be added as
>>>> a dependency?
>>> I added a Cmake module to get some Git parameters, if available.
>>> It should check if it's not a Git repository, though I didn't think
>>> about it could fail if Git is not installed at all.
>>> Thanks for the comment, because I didn't think about it at all.
>>> I thought the Git module would be smart enough, but of course this
>>> shouldn't become a build dependency.
>>> Will take a look.
>>> Daniel
>>>> Best,
>>>> Steve
>>>> _______________________________________________
>>>> pgrouting-dev mailing list
>>>> pgrouting-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>> Georepublic UG & Georepublic Japan
>>> eMail: daniel.kastl at georepublic.de
>>> Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20130510/839142c5/attachment-0001.html>
More information about the pgrouting-dev mailing list
