[pgrouting-dev] PGR-2: Add some robustness to the boost wrappers
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 15 18:51:30 PDT 2013
Hi all,
I have looking into how to fix issue #32 which has to do with a fatal
error happening deep in the boost code.
I think we have the info we need to fix this issue in C++ but I need
some C++ developer help as you already know.
Anyway I have found a simple way to catch these error and without
crashing the server. In all likelihood, this will cause memory leaks
which probably will require a graceful server restart, but at least it
won't be a hard crash like before.
So the pattern for this is to simply wrapt the whole body of any C++
code that is called from C with a try-cacth block like:
int my_cpp_function(args...)
   try {
     //function body
     return EXIT_SUCCESS;
   catch(...) {
     return -1;
So I just added this change to the following files:
src/apsp_johnson/src/apsp_johnson_boost_wrapper.cpp
src/apsp_warshall/src/apsp_boost_wrapper.cpp
src/astar/src/astar_boost_wrapper.cpp
src/dijkstra/src/boost_wrapper.cpp
src/dijkstra/tester/boost_wrapper.cpp
src/driving_distance/src/boost_drivedist.cpp
and my test file for issue #32 now reports:
pgr_test=# SELECT * FROM pgr_dijkstra('SELECT id, source, target, cost
FROM network', 4401489, 4401483, false, false) ;
ERROR:  Error computing path: Unknown exception caught!
but it does not crash the server.
Progress in small steps!
-Steve
More information about the pgrouting-dev mailing list
