[pgrouting-dev] K-Dijkstra code
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 22 08:01:57 PDT 2013
Pushed under branch name kdijkstra-merge
-Steve
On 5/22/2013 10:32 AM, Daniel Kastl wrote:
> On Wed, May 22, 2013 at 4:48 AM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Daniel,
>     I have merged the KDijkstra fork into a private branch, but it is
>     using some strange result types. Also there are two functions, one
>     returns a cost and the other returns the geoms but they both take
>     the same args and have different names.
>     So I'm going to need to spend some time with this and see if I can
>     make is cleanly fit the model we have for the other functions.
> Hi Steve,
> If you push this branch to Github, then I can also try out. ;-)
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
