[pgrouting-dev] K-Dijkstra code
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 22 08:46:39 PDT 2013
Daniel,
If you can make a working example for the existing code that would help me.
Thanks,
   -Steve
On 5/22/2013 11:01 AM, Stephen Woodbridge wrote:
> Pushed under branch name kdijkstra-merge
> -Steve
> On 5/22/2013 10:32 AM, Daniel Kastl wrote:
>> On Wed, May 22, 2013 at 4:48 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>     Daniel,
>>     I have merged the KDijkstra fork into a private branch, but it is
>>     using some strange result types. Also there are two functions, one
>>     returns a cost and the other returns the geoms but they both take
>>     the same args and have different names.
>>     So I'm going to need to spend some time with this and see if I can
>>     make is cleanly fit the model we have for the other functions.
>> Hi Steve,
>> If you push this branch to Github, then I can also try out. ;-)
>> Daniel
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
>> Web: http://georepublic.de <http://georepublic.de/>
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
