[pgrouting-dev] pgRouting Release Process Checklist
Worth Lutz wal3 at mindspring.com
Fri May 31 03:32:28 PDT 2013
 git branch -v
It will show all your branches with the active one marked.
-----Original Message-----
[mailto:pgrouting-dev-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Thursday, May 30, 2013 9:29 PM
To: pgrouting-dev at lists.osgeo.org
Subject: Re: [pgrouting-dev] pgRouting Release Process Checklist
Yes, I really like this model and keep a copy here on my desktop. I have
been using it for big changes. For little stuff, I just work in the
develop branch, but the problem is that things that start out small
often turn into larger projects.
I also need a better way from the command line to know what branch I'm
in because a few times I have been in the wrong branch and made changes
which is just as big a problem as forgetting to make a branch.
But, yes really good stuff, and incorporated in our developer guide.
Thanks for the suggestion,
   -Steve
More information about the pgrouting-dev mailing list
