[pgrouting-dev] Building some tools to work with TSP
Helder Alves helderalvespt at gmail.com
Tue Nov 12 15:45:46 PST 2013
OK, Steve... Thanks for the explanation!
It helps a lot because one of my doubts was precisely that need to compute
the routes again, after those same routes to have been computed already. I
thought I was missing some point there but now I understand that is the
only way.
I'll continue my exploration into pgRouting world for a couple of weeks
more and after that I must come up with a plan where I'll try to find out a
way of contributing somehow to your RFC's efforts, as clearly they are
headed to the same features I need.
Helder Alves
+351912384076
On Tue, Nov 12, 2013 at 8:23 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 11/12/2013 2:51 PM, Helder Alves wrote:
>> Hi Steve,
>> Thanks for the update!
>> I'm trying the new code but is not clear to me what's the best query to
>> get the total distance (in meters or kilometers) / time (in secs,
>> minutes or hours) for the route generated by TSP function (using a
>> distance matrix) and also how to get the geometry data needed to get
>> that same route represented as a QGIS layer.
> OK, when you make your distance matrix, the values in it are based on the
> cost function that you use to generate it.
> So for example it you have two columns in your edge table, like
> cost_distance and cost_time, then when you create your distance matrix and
> select the edges using cost_time as cost, then your distance matrix is
> based on time. The units are whatever you use in the columns. Likewise if
> you build your matrix with cost_distance as cost then your distance matrix
> is based on the cost_distance values in whatever units you used for that
> column.
> TSP ONLY orders the nodes, if you need the routes between the nodes then
> those have to be computed again based on the ordered nodes.
> I say "again", because we computed them internally when we computed the
> distance matrix. But these were not cached anywhere, so they will have to
> be computed again after the TSP has ordered the nodes.
> I have been side tracked, looking into whether or not I can integrate a
> local OSRM instance into pgrouting because if you don't need the dynamic
> graph definition, ie: you can live with a static graph definition, then
> OSRM would allow for some significant performance gains in computing
> distance matrices and routes.
> I have also looked at some additional wrapping of the TSP and routing with
> an eye toward caching the routes generated in dmatrix creation for later
> use to generate the routes.
> So the bottom line is you are needing the stuff I am developing. I need it
> also, but it takes time to design and code stuff, especially while putting
> out other fires. And all the code (whatever that might turn out to be) is
> not there yet.
> -Steve
>  I guess I'm missing something but after reading everything thoroughly
>> I'm not getting there...
>> Helder Alves
>> +351912384076
>> On Sun, Nov 10, 2013 at 2:40 PM, Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>     Hello Helder,
>>     Did you notice that I checked in a new version of
>>     pgr_vidstodmatrix() with a different signature that is 3x faster.
>>     Also the function you are using below will likely go away as it was
>>     just a quick prototype so you should move your code to the new
>> function.
>>     Thank you for giving them a try.
>>     -Steve
>>     On 11/5/2013 7:53 PM, Helder Alves wrote:
>>         It's working! Thanks! :-)
>>         Helder Alves
>>         +351912384076 <tel:%2B351912384076>
>>         On Mon, Nov 4, 2013 at 6:42 PM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge.__com
>>         <mailto:woodbri at swoodbridge.com>>> wrote:
>>              You ways table does not have a column named "id" for now
>>         you might
>>              have to set up a view like:
>>              create view v_ways as select your_id_col as id, source,
>>         target, cost
>>              from ways;
>>              then try your query replacing 'ways' with 'v_ways'
>>              -Steve
>>              On 11/4/2013 11:31 AM, Helder Alves wrote:
>>                  Hi Steve,
>>                       select dmatrix::float8[]
>>                               from pgr_vidstodmatrix(
>>                                        pgr_pointstovids(
>>         pgr_texttopoints('-7.50501,40.____26310;-7.48864,40.17530;-
>> 7.____49901,40.13950;-7.57596,40.____12350;-7.61591,40.
>> 13230;-7.____61935,40.13230;-7.67235,40.____13580;-7.67087,
>> 40.13660;-7.____66510,40.13860;-7.74559,40.____15640;-
>> 7.74588,40.15730;-7.____74746,40.15690;-7.74922,40.____
>> 15540;-7.74926,40.15310;-7.____73537,40.14230;-7.63556,40.__
>> __18920;-7.64849,40.22630;-7.____62354,40.25680;-7.62425,40.
>> ____26280;-7.62223,40.25830;-7.____62179,40.25680;-7.62116,
>> 40.____25580;-7.64803,40.22390;-7.____63916,40.20560;-
>> 7.63664,40.____20250;-7.63767,40.19970;-7.____63623,40.
>> 20000;-7.56974,40.____26710;-7.49104,40.26500;-7.____50473,40.26320',
>>                       4326),
>>                                            'ways'),
>>                       4326),
>>                                        'ways')
>>                  While running the query above, I got the error below.
>>                       column "id" does not exist
>>                       LINE 1: select id, source, target, cost from ways
>>         where
>>                  the_geom && ...
>>                       QUERY:  select id, source, target, cost from ways
>>         where
>>                  the_geom &&
>>         '____0103000020E6100000010000000500______
>> 00002E34D769A4651FC05EBA490C02______0344402E34D769A4651FC0492EFF21______
>> FD2E444076ABE7A4F78D1DC0492EFF______21FD2E444076ABE7A4F78D1DC05EBA______
>> 490C020344402E34D769A4651FC05E____BA490C02034440'::geometry
>>                       CONTEXT:  PL/pgSQL function
>>                       pgr_vidstodmatrix(integer[],__
>> __geometry[],text,double
>>                  precision) line
>>                       57 at FOR over EXECUTE statement
>>                  I guess it's some kind of bug, which is something it
>>         may happen
>>                  when we
>>                  are testing something from the develop branch! :-)
>>                  Can you help me with this?
>>                  Thanks!
>>                  Helder Alves
>>         +351912384076 <tel:%2B351912384076> <tel:%2B351912384076>
>>                  On Wed, Oct 9, 2013 at 5:26 PM, Stephen Woodbridge
>>         <mailto:woodbri at swoodbridge.__com <mailto:woodbri at swoodbridge.com
>>         <mailto:woodbri at swoodbridge.>____com
>>         <mailto:woodbri at swoodbridge.com>>>> wrote:
>>                       Another common problem is orienting the returned
>>         edges so
>>                  they match
>>                       up end to end. For example:
>>                          select st_astext(the_geom) from
>>         pgr_tsptrsp(pgr_texttopoints('______2,0;2,1;3,1;2,2;4,1;4,2;
>> 2,__3;__3,__2',
>>                       0), 'edge_table', true, true) a, edge_table b where
>>                  a.id2=b.id <http://b.id> <http://b.id>
>>                       <http://b.id>;
>>                       "LINESTRING(2 1,2 2)"
>>                       "LINESTRING(2 2,3 2)"
>>                       "LINESTRING(3 2,4 2)"
>>                       "LINESTRING(4 1,4 2)"  -- needs to be flipped
>>                       "LINESTRING(3 1,4 1)"  -- needs to be flipped
>>                       "LINESTRING(2 1,3 1)"  -- needs to be flipped
>>                       "LINESTRING(2 2,2 3)"
>>                       "LINESTRING(2 2,2 3)"  -- needs to be flipped
>>                       "LINESTRING(2 1,2 2)"  -- needs to be flipped
>>                       "LINESTRING(2 0,2 1)"  -- needs to be flipped
>>                       So I wrote a new function pgr_flipedges(ga
>>         geometry[]) that
>>                  can be
>>                       used like this:
>>                       select st_astext(e) from (
>>                          select
>>         unnest(pgr_flipedges(array_______agg(the_geom))) as e
>>                            from
>> 2,__3;__3,__2',
>>                                 edge_table b
>>                           where a.id2=b.id <http://b.id> <http://b.id>
>>         <http://b.id>
>>                       ) as foo;
>>                       "LINESTRING(4 2,4 1)"
>>                       "LINESTRING(4 1,3 1)"
>>                       "LINESTRING(3 1,2 1)"
>>                       "LINESTRING(2 3,2 2)"
>>                       "LINESTRING(2 2,2 1)"
>>                       "LINESTRING(2 1,2 0)"
>>                       Notice how all the edges have been flipped to
>> return a
>>                  continuous
>>                       path from start to end of each adjacent segment in
>>         the path.
>>                       -Steve
>>                       All the mentioned code will eventually get checked
>>         into
>>                  pgrouting
>>                       2.1 development branch once it is stable and I
>>         have test
>>                  cases and
>>                       docs written for it.
>>                       -Steve
>>                       On 10/9/2013 10:29 AM, Stephen Woodbridge wrote:
>>                           Hi all,
>>                           I have been playing with some tools to allow
>>         me  to
>>                  integrate TSP
>>                           optimization into a web application. I thought
>>         I would
>>                  share
>>                           what I have
>>                           come up with for comments. One of the things I
>>         did was
>>                  to try
>>                           and break
>>                           down the process into reusable modular
>>         functions. For
>>                  example
>>                           there are
>>                           two functions to compute the distance matrix
>>         based on
>>                  either
>>                           Euclidean
>>                           or kdijkstra distances. One could add other
>>         functions
>>                  to compute
>>                           them
>>                           based on other algorithms. Also each function
>>         does one
>>                           conversion so it
>>                           is simple to understand and easy to test or
>>         replace
>>                  with another
>>                           function that does the transformation in a
>>         different
>>                  way. Then
>>                           the final
>>                           function glues all the pieces together to get
>>         the final
>>                  result.
>>                           Goal:
>>                           take a string or points like "x,y;x,y;x,y;..."
>> and
>>                  compute the TSP
>>                           solution to order the points based on either
>>         Euclidean
>>                  distance or
>>                           network distances, then compute the route
>>         through the
>>                  network
>>                           and return
>>                           the route geometry.
>>                           Solution in progress:
>>                           1. text to point geometry *
>>                                pgr_texttopoints(pnts text, srid integer
>>                  DEFAULT(4326))
>>                           2. points to vertex ids *
>>                                pgr_pointtoedgenode(edges text, pnt
>>         geometry, tol
>>                  float8)
>>                                pgr_pointstovids(pnts geometry[], edges
>>         text, tol
>>                  float8
>>                           DEFAULT(0.01))
>>                           3. points to edge ids **
>>                           4. points to [edge id, pct] **
>>                           5. points to Euclidean distance matrix *
>>                                pgr_points2dmatrix(pnts geometry[], OUT
>>         dmatrix double
>>                           precision[],
>>                           OUT ids integer[])
>>                           6. vertex ids to kdijkstra distance matrix *
>>                                pgr_vidstodmatrix(IN vids integer[], IN
>> pnts
>>                  geometry[], IN
>>                           edges
>>                           text, tol float8 DEFAULT(0.1), OUT dmatrix
>> double
>>                  precision[],
>>                           OUT ids
>>                           integer[])
>>                           7. distance matrix to TSP to ordered list ***
>>                           select * from pgr_tsp(
>>                                 (select dmatrix::float8[]
>>                                             pgr_pointstovids(
>>           pgr_texttopoints('2,0;2,1;3,1;______2,2;4,1;4,2;2,3;3,2',
>>                           0),
>>                                                 'edge_table'),
>>         pgr_texttopoints('2,0;2,1;3,1;______2,2;4,1;4,2;2,3;3,2', 0),
>>                                             'edge_table')
>>                                 1
>>                           8. reorder vids based on ordered list *
>>                           9. compute trsp for pairs of vids in ordered
>>         list *,!
>>                                pgr_trsp(sql text, vids integer[],
>>         directed boolean,
>>                           has_reverse_cost boolean, turn_restrict_sql text
>>                  DEFAULT NULL::text)
>>                                pgr_tsptrsp(pnts geometry[], edges text,
>>         directed
>>                  boolean,
>>                           has_reverse_cost boolean, tol float8
>> DEFAULT(0.1),
>>                  turn_restrict_sql
>>                           text DEFAULT NULL::text)
>>                                select * from
>> 2,__3;__3,__2',
>>                           0),
>>                           'edge_table', true, true);
>>                           10. output results **
>>                           NOTES:
>>                           * - done
>>                           ** - not done
>>                           *** - already part of 2.0
>>                           ! - computing a route through via points can be
>>                  optimized in the
>>                           C/C++
>>                           code for better performance, but I currently
>> just
>>                  prototyped
>>                           this up in
>>                           plpgsql
>>                           Thoughts,
>>                               -Steve
>>           _____________________________________________________
>>                           pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.
>> osgeo.org>
>>                  <mailto:pgrouting-dev at lists.__osgeo.org
>>         <mailto:pgrouting-dev at lists.osgeo.org>>
>>         <mailto:pgrouting-dev at lists.>____osgeo.org <http://osgeo.org>
>>         <mailto:pgrouting-dev at lists.osgeo.org>>>
>>         http://lists.osgeo.org/______mailman/listinfo/pgrouting-dev
>>         <http://lists.osgeo.org/____mailman/listinfo/pgrouting-dev>
>>         <http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev>__>
>>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>__>__>
>> osgeo.org>
>> osgeo.org>
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131112/e63a42b1/attachment-0001.html>
More information about the pgrouting-dev mailing list
