[pgrouting-dev] Routing instructions/Nav directions on pgRouting
Stephen Woodbridge woodbri at swoodbridge.com
Thu Nov 28 08:26:57 PST 2013
On 11/28/2013 11:14 AM, Paulo Figueiras wrote:
> Hello, Stephen.
> It was a wild shot, but I was already expecting that. I already saw the
> wiki page.
> Well, thanks anyway, and I'll keep working on this. Maybe I will have to
> do a driving directions procedure myself :) If I manage to do something
> nice, I'll share it with the guys in the mailing list.
I'm will to work with you to add something generic to pgRouting, I just
don't have time to do 100% of it myself. The coding part is not too hard
once you have worked out a design, and then the documentation and test
cases take a lot of time.
If you have questions feel free to ask.
-Steve
> Thanks again, Stephen, Daniel.
> Regards,
> 2013/11/28 Stephen Woodbridge <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>>
>     Hi Paulo,
>     Sorry, the implementation that I have is was developed for a
>     specific client and is very much tied to their data and table
>     structure and I am not allow to distribute it.
>     I have written up how to do this on a wiki page here:
>     https://github.com/pgRouting/__pgrouting/wiki/Driving-__Direction-Instructions
>     <https://github.com/pgRouting/pgrouting/wiki/Driving-Direction-Instructions>
>     -Steve
>     On 11/28/2013 9:42 AM, Paulo Figueiras wrote:
>         Hello, Daniel.
>         Thank you for your quick reply. Well, for now I wouldn't want to
>         enrol
>         myself in such an endeavor :) . I would prefer to use something
>         that is
>         already done, even if it is much simpler than other routing engines'
>         driving instructions.
>         I was reading one thread of your mailing list where you guys
>         talk about
>         the solution presented by Stephen Woodbridge, using iMapTools,
>         and I was
>         wondering if Stephen's algorithm is accessible for use, or if it
>         is a
>         private solution.
>         Do you know anything about this subject? Thank you very much.
>         Regards,
>         Paulo.
>         2013/11/28 Daniel Kastl <daniel at georepublic.de
>         <mailto:daniel at georepublic.de>
>         <mailto:daniel at georepublic.de <mailto:daniel at georepublic.de>>__>
>              On Thu, Nov 28, 2013 at 8:43 PM, Paulo Figueiras
>         <paf at uninova.pt <mailto:paf at uninova.pt>
>              <mailto:paf at uninova.pt <mailto:paf at uninova.pt>>> wrote:
>                  Greetings.
>                  I am a portuguese developer and I just started using
>         pgRouting
>                  as my routing engine. I chose it because it is very
>         flexible and
>                  scalable, and it is based on a relational database.
>                  This offers me other types of functionalities that normal
>                  routing engines don't.
>                  Even so, I need a higher-level functionality, namely route
>                  instructions or navigation directions, that pgRouting
>         does not
>                  provide for now (I think).
>                  I read some forum posts from people that had the same
>         problem as
>                  me. Some of them are really old (more than 2 years). I
>         found two
>                  ways of doing that:
>                      - One way is to implement a instruction algorithm,
>         such as
>                  the one described here:
>         http://lists.osgeo.org/__pipermail/pgrouting-users/__2011-January/000537.html
>         <http://lists.osgeo.org/pipermail/pgrouting-users/2011-January/000537.html>
>                      - The other way is to have an external service to
>         do that,
>                  such as,
>         http://techbase.kde.org/__Projects/Marble/__RoutingInstructions
>         <http://techbase.kde.org/Projects/Marble/RoutingInstructions>
>                  Now, my question is that neither one of the approaches
>         to having
>                  navigation directions from a pgRouting route is
>         optimized or
>                  well documented.
>                  Are there any new alternatives to these two approaches?
>         If not,
>                  is there a more developed solution to the route
>         instructions
>                  issue (commonly called Driving Directions issue) ?
>              Hi Paulo,
>              As you have already said, this question came up quite a few
>         times
>              already.
>              I think the reason, why there is no out-of-the-box solution
>         yet, is,
>              that it is very difficult (probably impossible) to provide
>         this kind
>              of driving instructions in a way that it works for any
>         (road) network.
>              And beside the variety of data there are also lots of
>         languages.
>              If you (or someone else) is able to draft a concept how to
>         produce
>              driving directions in a smart way, that it does not depend on a
>              specific dataset or language, then such a functionality
>         would be a
>              valuable contribution ... which might even attract some
>         funding ;)
>              Regards,
>              Daniel
>              Georepublic UG & Georepublic Japan
>              eMail: daniel.kastl at georepublic.de
>         <mailto:daniel.kastl at georepublic.de>
>         <mailto:daniel.kastl at __georepublic.de
>         <mailto:daniel.kastl at georepublic.de>>
>              Web: http://georepublic.de <http://georepublic.de/>
>              _________________________________________________
>              pgrouting-dev mailing list
>         pgrouting-dev at lists.osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>
>         <mailto:pgrouting-dev at lists.__osgeo.org
>         <mailto:pgrouting-dev at lists.osgeo.org>>
>         http://lists.osgeo.org/__mailman/listinfo/pgrouting-dev
>         <http://lists.osgeo.org/mailman/listinfo/pgrouting-dev>
>         Paulo Figueiras <paf at uninova.pt <mailto:paf at uninova.pt>
>         <mailto:%3Crddc at uninova.pt <mailto:3Crddc at uninova.pt>>>______
>         cid:image002.jpg at 01C8AEC7.__2F6E45A0 <http://www.uninova.pt/>____
>         __ __
>         UNINOVA, Centre of Technology and Systems
>         Campus da Caparica, Quinta da Torre
>         2829-516 Monte Caparica, PORTUGAL____
>         Phone: (+351) 212948312 <tel:%28%2B351%29%20212948312> | Fax:
>         (+351) 212957786 <tel:%28%2B351%29%20212957786> | Website:
>         pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> Paulo Figueiras <paf at uninova.pt <mailto:%3Crddc at uninova.pt>>____
> cid:image002.jpg at 01C8AEC7.2F6E45A0 <http://www.uninova.pt/>____
> __ __
> Phone: (+351) 212948312 | Fax: (+351) 212957786 | Website:
More information about the pgrouting-dev mailing list
