[pgrouting-dev] Routing instructions/Nav directions on pgRouting
Paulo Figueiras paf at uninova.pt
Thu Nov 28 08:14:45 PST 2013
Hello, Stephen.
It was a wild shot, but I was already expecting that. I already saw the
wiki page.
Well, thanks anyway, and I'll keep working on this. Maybe I will have to do
a driving directions procedure myself :) If I manage to do something nice,
I'll share it with the guys in the mailing list.
Thanks again, Stephen, Daniel.
Regards,
2013/11/28 Stephen Woodbridge <woodbri at swoodbridge.com>
> Hi Paulo,
> Sorry, the implementation that I have is was developed for a specific
> client and is very much tied to their data and table structure and I am not
> allow to distribute it.
> I have written up how to do this on a wiki page here:
> https://github.com/pgRouting/pgrouting/wiki/Driving-Direction-Instructions
> -Steve
> On 11/28/2013 9:42 AM, Paulo Figueiras wrote:
>> Hello, Daniel.
>> Thank you for your quick reply. Well, for now I wouldn't want to enrol
>> myself in such an endeavor :) . I would prefer to use something that is
>> already done, even if it is much simpler than other routing engines'
>> driving instructions.
>> I was reading one thread of your mailing list where you guys talk about
>> the solution presented by Stephen Woodbridge, using iMapTools, and I was
>> wondering if Stephen's algorithm is accessible for use, or if it is a
>> private solution.
>> Do you know anything about this subject? Thank you very much.
>> Regards,
>> Paulo.
>> 2013/11/28 Daniel Kastl <daniel at georepublic.de
>> <mailto:daniel at georepublic.de>>
>>     On Thu, Nov 28, 2013 at 8:43 PM, Paulo Figueiras <paf at uninova.pt
>>     <mailto:paf at uninova.pt>> wrote:
>>         Greetings.
>>         I am a portuguese developer and I just started using pgRouting
>>         as my routing engine. I chose it because it is very flexible and
>>         scalable, and it is based on a relational database.
>>         This offers me other types of functionalities that normal
>>         routing engines don't.
>>         Even so, I need a higher-level functionality, namely route
>>         instructions or navigation directions, that pgRouting does not
>>         provide for now (I think).
>>         I read some forum posts from people that had the same problem as
>>         me. Some of them are really old (more than 2 years). I found two
>>         ways of doing that:
>>             - One way is to implement a instruction algorithm, such as
>>         the one described here:
>>         http://lists.osgeo.org/pipermail/pgrouting-users/
>> 2011-January/000537.html
>>             - The other way is to have an external service to do that,
>>         such as, http://techbase.kde.org/Projects/Marble/
>> RoutingInstructions
>>         Now, my question is that neither one of the approaches to having
>>         navigation directions from a pgRouting route is optimized or
>>         well documented.
>>         Are there any new alternatives to these two approaches? If not,
>>         is there a more developed solution to the route instructions
>>         issue (commonly called Driving Directions issue) ?
>>     Hi Paulo,
>>     As you have already said, this question came up quite a few times
>>     already.
>>     I think the reason, why there is no out-of-the-box solution yet, is,
>>     that it is very difficult (probably impossible) to provide this kind
>>     of driving instructions in a way that it works for any (road) network.
>>     And beside the variety of data there are also lots of languages.
>>     If you (or someone else) is able to draft a concept how to produce
>>     driving directions in a smart way, that it does not depend on a
>>     specific dataset or language, then such a functionality would be a
>>     valuable contribution ... which might even attract some funding ;)
>>     Regards,
>>     Daniel
>>     Georepublic UG & Georepublic Japan
>>     eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl@
>> georepublic.de>
>>     Web: http://georepublic.de <http://georepublic.de/>
>>     _______________________________________________
>>     pgrouting-dev mailing list
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>>     http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Paulo Figueiras <paf at uninova.pt <mailto:%3Crddc at uninova.pt>>____
>> cid:image002.jpg at 01C8AEC7.2F6E45A0 <http://www.uninova.pt/>____
>> __ __
>> UNINOVA, Centre of Technology and Systems
>> Campus da Caparica, Quinta da Torre
>> 2829-516 Monte Caparica, PORTUGAL____
>> Phone: (+351) 212948312 | Fax: (+351) 212957786 | Website:
Paulo Figueiras <paf at uninova.pt <%3Crddc at uninova.pt>>
[image: cid:image002.jpg at 01C8AEC7.2F6E45A0] <http://www.uninova.pt/>
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131128/71bed0fa/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131128/71bed0fa/attachment.jpg>
More information about the pgrouting-dev mailing list
