[pgrouting-dev] OSM processing erases some nodes?
Manikanta Kondeti mani.iiit123 at gmail.com
Wed Jan 29 10:48:51 PST 2014
Hello Sir ,
            I too have the same problem when I developed a web application
few months back. I loaded the data using osm2pgrouting & used  pgDijkstra
Algorithm to  get the route. I have attached screenshots of that errors.
But when I load this using QGIS its showing perfectly. So I thought data
which is in database is perfect and there is some error with my
application.  Am I right :?
Regards
Manikanta
B.Tech & MS in Computer Science,
Lab for Spatial Informatics,
IIIT Hyderabad
On Wed, Jan 29, 2014 at 11:03 PM, Paulo Figueiras <paf at uninova.pt> wrote:
> Hi, guys.
> Simple question. Can anyone tell me if the osm2pgrouting procedure removes
> any nodes from the osm when processing the OSM file, i.e., does it cut
> nodes that may be uninteresting?
> I calculated a route with Dijkstra, but when I plot it on a map, there are
> some nodes missing, i.e., the route does not always follow the road.
> Thanks in advance. Best,
> Paulo Figueiras <paf at uninova.pt <%3Crddc at uninova.pt>>
> [image: cid:image002.jpg at 01C8AEC7.2F6E45A0] <http://www.uninova.pt/>
> UNINOVA, Centre of Technology and Systems
> Campus da Caparica, Quinta da Torre
> 2829-516 Monte Caparica, PORTUGAL
> Phone: (+351) 212948312 | Fax: (+351) 212957786 | Website:
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140130/b33c8c2c/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140130/b33c8c2c/attachment-0001.jpg>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140130/b33c8c2c/attachment-0001.png>
More information about the pgrouting-dev mailing list
