[pgrouting-dev] OSM processing erases some nodes?
Daniel Kastl daniel at georepublic.de
Wed Jan 29 14:11:23 PST 2014
On Thu, Jan 30, 2014 at 3:48 AM, Manikanta Kondeti
<mani.iiit123 at gmail.com>wrote:
> Hello Sir ,
>             I too have the same problem when I developed a web application
> few months back. I loaded the data using osm2pgrouting & used  pgDijkstra
> Algorithm to  get the route. I have attached screenshots of that errors.
> But when I load this using QGIS its showing perfectly. So I thought data
> which is in database is perfect and there is some error with my
> application.  Am I right :?
> Regards
> Manikanta
> B.Tech & MS in Computer Science,
> Lab for Spatial Informatics,
> IIIT Hyderabad
> On Wed, Jan 29, 2014 at 11:03 PM, Paulo Figueiras <paf at uninova.pt> wrote:
>> Hi, guys.
>> Simple question. Can anyone tell me if the osm2pgrouting procedure
>> removes any nodes from the osm when processing the OSM file, i.e., does it
>> cut nodes that may be uninteresting?
>> I calculated a route with Dijkstra, but when I plot it on a map, there
>> are some nodes missing, i.e., the route does not always follow the road.
osm2pgrouting ignores OSM tags, which are not specified in the
configuration file:
https://github.com/pgRouting/osm2pgrouting/blob/master/mapconfig.xml
Not sure this is the problem though, but might be.
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140130/06b4c3dc/attachment.html>
More information about the pgrouting-dev mailing list
