[pgrouting-dev] Implementing Pickup and Delivery Problem for pgRouting
Manikanta Kondeti mani.iiit123 at gmail.com
Sun Jul 6 04:35:22 PDT 2014
Hi all,
This is Manikanta. I'm a GSoC student implementing VRP-Pickup and Delivery
problem for pgRouting. After reading many resources I had planned to solve
the problem in two main steps.
          1.) *Getting Initial Feasible Solution*
          2.) *Optimizing the initial solution using TABU search *
So according to the plan I had done first step i.e getting initial
solution.  Both my mentors helped me in solving the issues I faced. I just
want to inform this  in the developers list and get some
feedback/suggestions.
Here is the* link* to source code I've written:
https://github.com/pgRouting/pgrouting/tree/gsoc-vrppdtw/src/vrppdtw/src
*How to run: *
compile:   g++ pdp.cpp -o pdp
execute:   ./pdp < <input_file>
*Sample Test Cases:*
There are two directories which contain input files and corresponding
output files.
*Wiki: *
https://github.com/pgRouting/pgrouting/wiki/VRP-Pickup-Delivery-Problem
Suggestions are welcome. The two steps are for solving the problem, there
is a big task left after that, i.e.. integrating into pgRouting.
Thanks
Manikanta
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20140706/94f11db3/attachment.html>
More information about the pgrouting-dev mailing list
