[pgrouting-dev] Issue #329 + new flag
Vicky Vergara vicky_vergara at hotmail.com
Mon Apr 6 19:52:17 PDT 2015
Right now the functionality is this:
It cleans the table.
https://github.com/pgRouting/pgrouting/blob/master/src/common/sql/pgrouting_topology.sql#L527
the proposed functionality is:
https://github.com/cvvergara/pgrouting/blob/commonFunctionsUnderscore/src/common/sql/pgrouting_topology.sql#L206
https://github.com/cvvergara/pgrouting/blob/commonFunctionsUnderscore/src/common/sql/pgrouting_topology.sql#L226
So  clean = false, works only with rows where source or target are null
>>>In my opinion, what it shouldn't do is to drop the table by default ;-)So, I'll take that as:
clean = false   be the default.
Date: Tue, 7 Apr 2015 11:40:02 +0900
To: pgrouting-dev at lists.osgeo.org
Subject: Re: [pgrouting-dev] Issue #329 + new flag
 My personal preference is clean = False (Don't clean),  that is, it will continue with the topology where source & target values are null. That way if I add 100 rows to my 25million edges table, it will just add the topology for those 100 rows and not delete the existing topology and restart constructing the topology of 25million +100 edges.
Are you planning to improve the function to allow to continue updating topology if new data was added for example?
I think the case for the "clean" flag are:
* clean = True-> topology exists already -> drop and recreate topology without warning? -> topology doesn't exist -> create it
* clean = False-> topology exists already -> update topology?-> topology doesn't exist -> create it
Correct?
Daniel
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
pgrouting-dev mailing list
http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20150406/3b623435/attachment.html>
More information about the pgrouting-dev mailing list
