[pgrouting-dev] SSL SYSCALL error: EOF detected
Luís de Sousa luis.a.de.sousa at gmail.com
Fri Feb 20 02:58:14 PST 2015
Dear all,
I am presently implementing the Optimal Meeting Point (OMP) [0]
algorithm with PyWPS. I have a draft brute force algorithm that in
smaller networks computes the OMP correctly by testing all nodes of
the network with pgr_dijkstra (I am not yet using heuristics since
costs are not only distance dependent).
I am now testing this algorithm in a larger network, of some 50 000
nodes. I previously reported that for about 7%-8% of the nodes
pgr_dijkstra fails, returning an empty tuple [1]. After patching these
exceptions, I am stumping into another issue: somewhere between an
half and two thirds of the network have been processed, Postgres
crashes and I get the error: "SSL SYSCALL error: EOF detected" [2, 3].
This crash seems to happen randomly, with pgr_dijkstra invoked on
different nodes.
This issue should also be easy to circumvent, but it seems to be
symptom of something a bit more serious with pgrouting.
Regards,
Luís
[0] https://github.com/pgRouting/pgrouting/issues/289
[1] http://pgrouting-users.974093.n3.nabble.com/pgrouting-users-Empty-tuple-from-pgr-dijkstra-tp4025706.html
[2] http://stackoverflow.com/questions/20201711/pg-internalerror-ssl-syscall-error-eof-detected
[3] http://stackoverflow.com/questions/20217571/psycopg2-interfaceerror-connection-already-closed-pgr-astar
More information about the pgrouting-dev mailing list
