[pgrouting-dev] SSL SYSCALL error: EOF detected
Stephen Woodbridge woodbri at swoodbridge.com
Fri Feb 20 06:16:02 PST 2015
On 2/20/2015 5:58 AM, Luís de Sousa wrote:
> Dear all,
> I am presently implementing the Optimal Meeting Point (OMP) [0]
> algorithm with PyWPS. I have a draft brute force algorithm that in
> smaller networks computes the OMP correctly by testing all nodes of
> the network with pgr_dijkstra (I am not yet using heuristics since
> costs are not only distance dependent).
> I am now testing this algorithm in a larger network, of some 50 000
> nodes. I previously reported that for about 7%-8% of the nodes
> pgr_dijkstra fails, returning an empty tuple [1]. After patching these
> exceptions, I am stumping into another issue: somewhere between an
> half and two thirds of the network have been processed, Postgres
> crashes and I get the error: "SSL SYSCALL error: EOF detected" [2, 3].
> This crash seems to happen randomly, with pgr_dijkstra invoked on
> different nodes.
Hi Luís,
The error: "SSL SYSCALL error: EOF detected" is because the postgresql
backend has crashed and you connection in python has terminated.
> This issue should also be easy to circumvent, but it seems to be
> symptom of something a bit more serious with pgrouting.
There are a number of things that can crash the database, like running
out of memory, or running into a bug in the code.
google: gdb postgres stack trace
There are a couple of ways to get a stack trace of a crash.
1. is to enable core files
2. is to run the database under gdb
HTH,
   -Steve
> Regards,
> Luís
> [0] https://github.com/pgRouting/pgrouting/issues/289
> [1] http://pgrouting-users.974093.n3.nabble.com/pgrouting-users-Empty-tuple-from-pgr-dijkstra-tp4025706.html
> [2] http://stackoverflow.com/questions/20201711/pg-internalerror-ssl-syscall-error-eof-detected
> [3] http://stackoverflow.com/questions/20217571/psycopg2-interfaceerror-connection-already-closed-pgr-astar
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
