[pgrouting-dev] SSL SYSCALL error: EOF detected
Stephen Woodbridge woodbri at swoodbridge.com
Wed Feb 25 06:56:03 PST 2015
Luis,
Have tried running this query using pgr_trsp() instead of pgr_dijkstra()
SELECT seq, id1 AS node, id2 AS edge, cost, ST_AsGeoJSON(b.the_geom)
FROM pgr_trsp('
            SELECT gid AS id,
                 source::integer,
                 target::integer,
                 to_cost::double precision AS cost,
                 reverse_cost::double precision
            FROM  lux_2po.ways',
            10000 ,  20000 , true, true) a LEFT JOIN  lux_2po.ways b ON
(a.id2 = b.gid)
If this leaks the same way then I'm guessing the issue is with psycopg2
or how you are calling it. I have not used python interface to pg but in
other languages the pattern looks like:
connect to database
prepare a query
execute the query
loop through the results
free the results     <=======   **** this is a leak if not done ****
loop back to prepare or execute
disconnect from database
Q: have you watched the processes in top? is the postgres process
growing in size or is it the python or apache or other process that is
consuming all the memory?
If some other process consumes all the memory then postgres will fail
when it needs memory because there is none available.
-Steve
On 2/25/2015 4:28 AM, Luís de Sousa wrote:
> Just as an addendum, the network tables in this schema sum up to less
> than 34 Mb:
> # SELECT sum(c.relpages) * 8
>    FROM pg_class c,
>         pg_namespace n
>   WHERE c.relnamespace = n.oid
>     AND n.nspname LIKE 'lux_2po_2169'
>     AND c.relname LIKE 'ways%';
>   ?column?
>      33952
> (1 row)
> Thank you,
> Luís
> On 25 February 2015 at 10:06, Luís de Sousa <luis.a.de.sousa at gmail.com> wrote:
>> Hi again Steve,
>> I have ran valgrind with 4 and 10 queries, and as you expected, the
>> report is essentially the same (logs attached).
>> I have postgres crashing twice a day. The way psycopg2 opens and
>> maintains the connection is the only alternative suspect, but the
>> memory swell only takes place with the pgr_dijkstra function. Would
>> you have other suggestions? Or would you advise a different forum to
>> pose this issue?
>> Thank you,
>> Luís
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
