[pgrouting-dev] SSL SYSCALL error: EOF detected
Luís de Sousa luis.a.de.sousa at gmail.com
Wed Feb 25 07:18:22 PST 2015
Hi Steve,
I am sorry if I did not make this clear before: PyWPS is running on a
different server. Postgres and pgRouting run on a dedicated server; it
is always a postgres process taking up the RAM.
Thank you,
Luís
On 25 February 2015 at 15:56, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> Luis,
> Have tried running this query using pgr_trsp() instead of pgr_dijkstra()
> SELECT seq, id1 AS node, id2 AS edge, cost, ST_AsGeoJSON(b.the_geom)
> FROM pgr_trsp('
>            SELECT gid AS id,
>                 source::integer,
>                 target::integer,
>                 to_cost::double precision AS cost,
>                 reverse_cost::double precision
>            FROM  lux_2po.ways',
>            10000 ,  20000 , true, true) a LEFT JOIN  lux_2po.ways b ON
> (a.id2 = b.gid)
> If this leaks the same way then I'm guessing the issue is with psycopg2 or
> how you are calling it. I have not used python interface to pg but in other
> languages the pattern looks like:
> connect to database
> prepare a query
> execute the query
> loop through the results
> free the results     <=======   **** this is a leak if not done ****
> loop back to prepare or execute
> disconnect from database
> Q: have you watched the processes in top? is the postgres process growing in
> size or is it the python or apache or other process that is consuming all
> the memory?
> If some other process consumes all the memory then postgres will fail when
> it needs memory because there is none available.
> -Steve
> On 2/25/2015 4:28 AM, Luís de Sousa wrote:
>> Just as an addendum, the network tables in this schema sum up to less
>> than 34 Mb:
>> # SELECT sum(c.relpages) * 8
>>    FROM pg_class c,
>>         pg_namespace n
>>   WHERE c.relnamespace = n.oid
>>     AND n.nspname LIKE 'lux_2po_2169'
>>     AND c.relname LIKE 'ways%';
>>   ?column?
>>      33952
>> (1 row)
>> Thank you,
>> Luís
>> On 25 February 2015 at 10:06, Luís de Sousa <luis.a.de.sousa at gmail.com>
>> wrote:
>>> Hi again Steve,
>>> I have ran valgrind with 4 and 10 queries, and as you expected, the
>>> report is essentially the same (logs attached).
>>> I have postgres crashing twice a day. The way psycopg2 opens and
>>> maintains the connection is the only alternative suspect, but the
>>> memory swell only takes place with the pgr_dijkstra function. Would
>>> you have other suggestions? Or would you advise a different forum to
>>> pose this issue?
>>> Thank you,
>>> Luís
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
More information about the pgrouting-dev mailing list
