[pgrouting-dev] SSL SYSCALL error: EOF detected
Luís de Sousa luis.a.de.sousa at gmail.com
Thu Feb 26 01:14:09 PST 2015
Hi again Steve, a few more points:
1. I am using pgRouting 2.0.0 on Ubuntu 12.04 server, with all the
software installed from the repositories. I am attaching a log file
with details.
2. Valgrind produces exactly the same output for pgr_trsp(). I am
attaching a log from five successive calls to this function.
3. Also attached is a small python script that replicates the issue.
Rough numbers, RAM usage in the Postgres server swells by about 160 Mb
per 10 000 queries. Just give it a go and let it run for a while.
Thank you and regards,
Luís
On 25 February 2015 at 17:01, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> On 2/25/2015 10:18 AM, Luís de Sousa wrote:
>> Hi Steve,
>> I am sorry if I did not make this clear before: PyWPS is running on a
>> different server. Postgres and pgRouting run on a dedicated server; it
>> is always a postgres process taking up the RAM.
> You may have and I may have forgotten :)
> Anyway, try using pgr_trsp() and see if it happen with that.
> Tell me about the postgresql server:
> What OS/Distribution?
> Are you using pgrouting installed from a package or compiled from source?
> select * from pgr_version();
> "2.0.0";"pgrouting-2.0.0";"78";"abde224";"develop";"1.46.1"
> My version is built from source and the "develop" branch using Boost v1.46.1
> with 78 commits ahead of master.
> Since pgr_trsp uses different code from pgr_dijkstra I would not expect to
> see the same behavior.
> -Steve
Type: text/x-python
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20150226/9398fbbf/attachment.py>
Type: application/octet-stream
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20150226/9398fbbf/attachment.obj>
Type: text/x-log
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20150226/9398fbbf/attachment.bin>
More information about the pgrouting-dev mailing list
