[pgrouting-dev] How do I work on pgRouting documentation?
Vicky Vergara vicky at georepublic.de
Fri Jul 8 20:18:20 PDT 2016
I merged code and more documentation to develop.
Here is a helpful link for keeping up to date the branches:
http://docs.pgrouting.org/doxy/2.3-dev-develop/index.html#up_to_date
On Wed, Jun 22, 2016 at 7:57 PM, Vicky Vergara <vicky at georepublic.de> wrote:
> Thanks
> On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz <wal3 at mindspring.com> wrote:
>> Vicky,
>> My github is at:
>>     https://github.com/worthlutz/pgrouting/
>> The branch I'll be using is *doc-improvements* branched off *develop*.
>> I'll let you know when I push some changes.
>> *Worth Lutz*
>> On 06/22/2016 02:06 PM, Vicky Vergara wrote:
>> Tell when you make the branch
>> so I can pinpoint where to find the docuemtnation
>> On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz <wal3 at mindspring.com> wrote:
>>> Thanks Vicky.  I'll let you know what I find.
>>> *Worth Lutz*
>>> On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>>> Hello Worth Lutz.
>>> The documentation changes you made them to master or to develop?
>>> Right now develop documentation has changed, not in everything put it
>>> has lots of changes.
>>> http://docs.pgrouting.org/dev/en/doc/index.html
>>> It is better for us to work on the develop branch which has the 2.3
>>> documentation.
>>> Its changing a lot. so to have the current contents of develop in your
>>> for:
>>> git checkout develop
>>> git fetch upstream
>>> git merge upstream/develop
>>> git push
>>> then in the github site you will be able to see that it contains the
>>> current contents of develop.
>>> Then you can branch to a working directory
>>> git checkout -b 'improve/documentation'
>>> then do a
>>> git push
>>> and give me the link to the branch in your repository so that if I make
>>> changes to develop's documentation, I can make a pull request to your
>>> branch with the changes I made.
>>> Work on the documentation, and make pull requests to develop.
>>> thanks.
>>> Vicky from the pgRouting team
>>> On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz < <wal3 at mindspring.com>
>>>> If I want to work on some errors/typos in the documentation, how do I
>>>> do that?
>>>> I've got a fork and want to create a pull request.
>>>> Which branch should I be working on?
>>>> As I'm starting a new routing project, I'm reading (and rereading) the
>>>> documentation a lot and think I should fix what I find.
>>>> *Worth Lutz*
>>>> _______________________________________________
>>>> pgrouting-dev mailing list
>>>> pgrouting-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>> Georepublic UG (haftungsbeschränkt)
>>> Salzmannstraße 44,
>>> 81739 München, Germany
>>> Vicky Vergara
>>> Operations Research
>>> eMail: vicky at georepublic.de
>>> Web: https://georepublic.info
>>> Tel: +49 (089) 4161 7698-1
>>> Fax: +49 (089) 4161 7698-9
>>> Commercial register: Amtsgericht München, HRB 181428
>>> CEO: Daniel Kastl
>>> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Salzmannstraße 44,
>> Vicky Vergara
>> Operations Research
>> CEO: Daniel Kastl
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160708/f1d90121/attachment.html>
More information about the pgrouting-dev mailing list
