[pgrouting-dev] How do I work on pgRouting documentation?
Worth Lutz wal3 at mindspring.com
Sat Jul 9 05:15:39 PDT 2016
I have been side tracked a bit but have been reading the documentation
extensively over the past week. I have had some success working with my
data and will be rereading the docs to make sure my understanding is
correct. I'll then commit the corrections and additions I'm working on.
How do I run the docs locally.  I am familiar with Sphinx but have not
found the place to
    /make html/
I see a /make.bat/ file but that is for Windows.  I normally work on
Ubuntu and have a /Makefile/ in the directory as well as /make.bat/. Is
development normally done on Windows? And thus the /Makefile /removed
when make.bat was edited?
Thanks for your help.
/*Worth Lutz*/
On 7/8/2016 11:18 PM, Vicky Vergara wrote:
> I merged code and more documentation to develop.
> Here is a helpful link for keeping up to date the branches:
> http://docs.pgrouting.org/doxy/2.3-dev-develop/index.html#up_to_date
> On Wed, Jun 22, 2016 at 7:57 PM, Vicky Vergara <vicky at georepublic.de
> <mailto:vicky at georepublic.de>> wrote:
>     Thanks
>     On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz <wal3 at mindspring.com
>     <mailto:wal3 at mindspring.com>> wrote:
>         Vicky,
>         My github is at:
>         https://github.com/worthlutz/pgrouting/
>         The branch I'll be using is *doc-improvements* branched off
>         *develop*.
>         I'll let you know when I push some changes.
>         *Worth Lutz*
>         On 06/22/2016 02:06 PM, Vicky Vergara wrote:
>>         Tell when you make the branch
>>         so I can pinpoint where to find the docuemtnation
>>         On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz
>>         <wal3 at mindspring.com <mailto:wal3 at mindspring.com>> wrote:
>>             Thanks Vicky.  I'll let you know what I find.
>>             *Worth Lutz*
>>             On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>>>             Hello Worth Lutz.
>>>             The documentation changes you made them to master or to
>>>             develop?
>>>             Right now develop documentation has changed, not in
>>>             everything put it has lots of changes.
>>>             http://docs.pgrouting.org/dev/en/doc/index.html
>>>             It is better for us to work on the develop branch which
>>>             has the 2.3 documentation.
>>>             Its changing a lot. so to have the current contents of
>>>             develop in your for:
>>>             git checkout develop
>>>             git fetch upstream
>>>             git merge upstream/develop
>>>             git push
>>>             then in the github site you will be able to see that it
>>>             contains the current contents of develop.
>>>             Then you can branch to a working directory
>>>             git checkout -b 'improve/documentation'
>>>             then do a
>>>             git push
>>>             and give me the link to the branch in your repository so
>>>             that if I make changes to develop's documentation, I can
>>>             make a pull request to your branch with the changes I made.
>>>             Work on the documentation, and make pull requests to
>>>             develop.
>>>             thanks.
>>>             Vicky from the pgRouting team
>>>             On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz
>>>                 If I want to work on some errors/typos in the
>>>                 documentation, how do I do that?
>>>                 I've got a fork and want to create a pull request.
>>>                 Which branch should I be working on?
>>>                 As I'm starting a new routing project, I'm reading
>>>                 (and rereading) the documentation a lot and think I
>>>                 should fix what I find.
>>>                 *Worth Lutz*
>>>                 _______________________________________________
>>>                 pgrouting-dev mailing list
>>>                 pgrouting-dev at lists.osgeo.org
>>>                 <mailto:pgrouting-dev at lists.osgeo.org>
>>>                 http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>             Georepublic UG (haftungsbeschränkt)
>>>             Salzmannstraße 44,
>>>             81739 München, Germany
>>>             Vicky Vergara
>>>             Operations Research
>>>             eMail: vicky at georepublic.de <http://georepublic.de>
>>>             Web:https://georepublic.info
>>>             Tel: +49 (089) 4161 7698-1
>>>             Fax: +49 (089) 4161 7698-9
>>>             Commercial register: Amtsgericht München, HRB 181428
>>>             CEO: Daniel Kastl
>>         Salzmannstraße 44,
>>         Vicky Vergara
>>         Operations Research
>>         CEO: Daniel Kastl
>     Salzmannstraße 44,
>     Vicky Vergara
>     Operations Research
>     CEO: Daniel Kastl
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160709/97aeadd7/attachment-0001.html>
More information about the pgrouting-dev mailing list
