[pgrouting-dev] How do I work on pgRouting documentation?
Daniel Kastl daniel at georepublic.de
Sat Jul 9 07:05:36 PDT 2016
The documentation is compiled with cake using a special compile flag, see
https://github.com/pgrouting/pgrouting/tree/develop#compilation
We probably need to make this easier to find in the documentation ;-)
Cheers,
Daniel
On Jul 9, 2016 9:15 PM, "Worth Lutz" <wal3 at mindspring.com> wrote:
> I have been side tracked a bit but have been reading the documentation
> extensively over the past week. I have had some success working with my
> data and will be rereading the docs to make sure my understanding is
> correct. I'll then commit the corrections and additions I'm working on.
> How do I run the docs locally.  I am familiar with Sphinx but have not
> found the place to
> *make html*
> I see a *make.bat* file but that is for Windows.  I normally work on
> Ubuntu and have a *Makefile* in the directory as well as *make.bat*. Is
> development normally done on Windows? And thus the *Makefile *removed
> when make.bat was edited?
> Thanks for your help.
> *Worth Lutz*
> On 7/8/2016 11:18 PM, Vicky Vergara wrote:
> I merged code and more documentation to develop.
> Here is a helpful link for keeping up to date the branches:
> http://docs.pgrouting.org/doxy/2.3-dev-develop/index.html#up_to_date
> On Wed, Jun 22, 2016 at 7:57 PM, Vicky Vergara <vicky at georepublic.de>
> wrote:
>> Thanks
>> On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz <wal3 at mindspring.com> wrote:
>>> Vicky,
>>> My github is at:
>>>     https://github.com/worthlutz/pgrouting/
>>> The branch I'll be using is *doc-improvements* branched off *develop*.
>>> I'll let you know when I push some changes.
>>> *Worth Lutz*
>>> On 06/22/2016 02:06 PM, Vicky Vergara wrote:
>>> Tell when you make the branch
>>> so I can pinpoint where to find the docuemtnation
>>> On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz <wal3 at mindspring.com>
>>> wrote:
>>>> Thanks Vicky.  I'll let you know what I find.
>>>> *Worth Lutz*
>>>> On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>>>> Hello Worth Lutz.
>>>> The documentation changes you made them to master or to develop?
>>>> Right now develop documentation has changed, not in everything put it
>>>> has lots of changes.
>>>> http://docs.pgrouting.org/dev/en/doc/index.html
>>>> It is better for us to work on the develop branch which has the 2.3
>>>> documentation.
>>>> Its changing a lot. so to have the current contents of develop in your
>>>> for:
>>>> git checkout develop
>>>> git fetch upstream
>>>> git merge upstream/develop
>>>> git push
>>>> then in the github site you will be able to see that it contains the
>>>> current contents of develop.
>>>> Then you can branch to a working directory
>>>> git checkout -b 'improve/documentation'
>>>> then do a
>>>> git push
>>>> and give me the link to the branch in your repository so that if I make
>>>> changes to develop's documentation, I can make a pull request to your
>>>> branch with the changes I made.
>>>> Work on the documentation, and make pull requests to develop.
>>>> thanks.
>>>> Vicky from the pgRouting team
>>>> On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz <wal3 at mindspring.com>
>>>> wrote:
>>>>> If I want to work on some errors/typos in the documentation, how do I
>>>>> do that?
>>>>> I've got a fork and want to create a pull request.
>>>>> Which branch should I be working on?
>>>>> As I'm starting a new routing project, I'm reading (and rereading) the
>>>>> documentation a lot and think I should fix what I find.
>>>>> *Worth Lutz*
>>>>> _______________________________________________
>>>>> pgrouting-dev mailing list
>>>>> pgrouting-dev at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>> Georepublic UG (haftungsbeschränkt)
>>>> Salzmannstraße 44,
>>>> 81739 München, Germany
>>>> Vicky Vergara
>>>> Operations Research
>>>> eMail: vicky at georepublic.de
>>>> Web: https://georepublic.info
>>>> Tel: +49 (089) 4161 7698-1
>>>> Fax: +49 (089) 4161 7698-9
>>>> Commercial register: Amtsgericht München, HRB 181428
>>>> CEO: Daniel Kastl
>>>> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>> Salzmannstraße 44,
>>> Vicky Vergara
>>> Operations Research
>>> CEO: Daniel Kastl
>> Salzmannstraße 44,
>> Vicky Vergara
>> Operations Research
>> CEO: Daniel Kastl
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160709/7747aabd/attachment-0001.html>
More information about the pgrouting-dev mailing list
