[pgrouting-dev] How do I work on pgRouting documentation?
Daniel Kastl daniel at georepublic.de
Sat Jul 9 07:06:44 PDT 2016
Sorry, should be "cmake" of course.
... auto correction...
On Jul 9, 2016 11:05 PM, "Daniel Kastl" <daniel at georepublic.de> wrote:
> The documentation is compiled with cake using a special compile flag, see
> https://github.com/pgrouting/pgrouting/tree/develop#compilation
> We probably need to make this easier to find in the documentation ;-)
> Cheers,
> Daniel
> On Jul 9, 2016 9:15 PM, "Worth Lutz" <wal3 at mindspring.com> wrote:
>> I have been side tracked a bit but have been reading the documentation
>> extensively over the past week. I have had some success working with my
>> data and will be rereading the docs to make sure my understanding is
>> correct. I'll then commit the corrections and additions I'm working on.
>> How do I run the docs locally.  I am familiar with Sphinx but have not
>> found the place to
>> *make html*
>> I see a *make.bat* file but that is for Windows.  I normally work on
>> Ubuntu and have a *Makefile* in the directory as well as *make.bat*. Is
>> development normally done on Windows? And thus the *Makefile *removed
>> when make.bat was edited?
>> Thanks for your help.
>> *Worth Lutz*
>> On 7/8/2016 11:18 PM, Vicky Vergara wrote:
>> I merged code and more documentation to develop.
>> Here is a helpful link for keeping up to date the branches:
>> http://docs.pgrouting.org/doxy/2.3-dev-develop/index.html#up_to_date
>> On Wed, Jun 22, 2016 at 7:57 PM, Vicky Vergara <vicky at georepublic.de>
>> wrote:
>>> Thanks
>>> On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz <wal3 at mindspring.com> wrote:
>>>> Vicky,
>>>> My github is at:
>>>>     https://github.com/worthlutz/pgrouting/
>>>> The branch I'll be using is *doc-improvements* branched off *develop*.
>>>> I'll let you know when I push some changes.
>>>> *Worth Lutz*
>>>> On 06/22/2016 02:06 PM, Vicky Vergara wrote:
>>>> Tell when you make the branch
>>>> so I can pinpoint where to find the docuemtnation
>>>> On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz <wal3 at mindspring.com>
>>>> wrote:
>>>>> Thanks Vicky.  I'll let you know what I find.
>>>>> *Worth Lutz*
>>>>> On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>>>>> Hello Worth Lutz.
>>>>> The documentation changes you made them to master or to develop?
>>>>> Right now develop documentation has changed, not in everything put it
>>>>> has lots of changes.
>>>>> http://docs.pgrouting.org/dev/en/doc/index.html
>>>>> It is better for us to work on the develop branch which has the 2.3
>>>>> documentation.
>>>>> Its changing a lot. so to have the current contents of develop in your
>>>>> for:
>>>>> git checkout develop
>>>>> git fetch upstream
>>>>> git merge upstream/develop
>>>>> git push
>>>>> then in the github site you will be able to see that it contains the
>>>>> current contents of develop.
>>>>> Then you can branch to a working directory
>>>>> git checkout -b 'improve/documentation'
>>>>> then do a
>>>>> git push
>>>>> and give me the link to the branch in your repository so that if I
>>>>> make changes to develop's documentation, I can make a pull request to your
>>>>> branch with the changes I made.
>>>>> Work on the documentation, and make pull requests to develop.
>>>>> thanks.
>>>>> Vicky from the pgRouting team
>>>>> On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz <wal3 at mindspring.com>
>>>>> wrote:
>>>>>> If I want to work on some errors/typos in the documentation, how do I
>>>>>> do that?
>>>>>> I've got a fork and want to create a pull request.
>>>>>> Which branch should I be working on?
>>>>>> As I'm starting a new routing project, I'm reading (and rereading)
>>>>>> the documentation a lot and think I should fix what I find.
>>>>>> *Worth Lutz*
>>>>>> _______________________________________________
>>>>>> pgrouting-dev mailing list
>>>>>> pgrouting-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>>> Georepublic UG (haftungsbeschränkt)
>>>>> Salzmannstraße 44,
>>>>> 81739 München, Germany
>>>>> Vicky Vergara
>>>>> Operations Research
>>>>> eMail: vicky at georepublic.de
>>>>> Web: https://georepublic.info
>>>>> Tel: +49 (089) 4161 7698-1
>>>>> Fax: +49 (089) 4161 7698-9
>>>>> Commercial register: Amtsgericht München, HRB 181428
>>>>> CEO: Daniel Kastl
>>>>> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>> Salzmannstraße 44,
>>>> Vicky Vergara
>>>> Operations Research
>>>> CEO: Daniel Kastl
>>> Salzmannstraße 44,
>>> Vicky Vergara
>>> Operations Research
>>> CEO: Daniel Kastl
>> Salzmannstraße 44,
>> Vicky Vergara
>> Operations Research
>> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160709/9658f74c/attachment-0001.html>
More information about the pgrouting-dev mailing list
