[pgrouting-dev] How do I work on pgRouting documentation?
Worth Lutz wal3 at mindspring.com
Sun Jul 10 07:16:20 PDT 2016
I tried all that and do not see where the updated documentation ends up.
After doing the build, pointing to:
     ~/pgrouting/build/doc/html/index.html
does not seem to work for me. I'm obviously missing something.
Thanks,*
*Worth Lutz*
On 7/9/2016 10:06 AM, Daniel Kastl wrote:
> Sorry, should be "cmake" of course.
> ... auto correction...
> On Jul 9, 2016 11:05 PM, "Daniel Kastl" <daniel at georepublic.de
> <mailto:daniel at georepublic.de>> wrote:
>     The documentation is compiled with cake using a special compile
>     flag, see
>     https://github.com/pgrouting/pgrouting/tree/develop#compilation
>     We probably need to make this easier to find in the documentation ;-)
>     Cheers,
>     Daniel
>     On Jul 9, 2016 9:15 PM, "Worth Lutz" <wal3 at mindspring.com
>     <mailto:wal3 at mindspring.com>> wrote:
>         I have been side tracked a bit but have been reading the
>         documentation extensively over the past week. I have had some
>         success working with my data and will be rereading the docs to
>         make sure my understanding is correct. I'll then commit the
>         corrections and additions I'm working on.
>         How do I run the docs locally.  I am familiar with Sphinx but
>         have not found the place to
>             /make html/
>         I see a /make.bat/ file but that is for Windows. I normally
>         work on Ubuntu and have a /Makefile/ in the directory as well
>         as /make.bat/. Is development normally done on Windows? And
>         thus the /Makefile /removed when make.bat was edited?
>         Thanks for your help.
>         /*Worth Lutz*/
>         On 7/8/2016 11:18 PM, Vicky Vergara wrote:
>>         I merged code and more documentation to develop.
>>         Here is a helpful link for keeping up to date the branches:
>>         http://docs.pgrouting.org/doxy/2.3-dev-develop/index.html#up_to_date
>>         On Wed, Jun 22, 2016 at 7:57 PM, Vicky Vergara
>>         <vicky at georepublic.de <mailto:vicky at georepublic.de>> wrote:
>>             Thanks
>>             On Wed, Jun 22, 2016 at 2:10 PM, Worth Lutz
>>             <wal3 at mindspring.com <mailto:wal3 at mindspring.com>> wrote:
>>                 Vicky,
>>                 My github is at:
>>                 https://github.com/worthlutz/pgrouting/
>>                 The branch I'll be using is *doc-improvements*
>>                 branched off *develop*.
>>                 I'll let you know when I push some changes.
>>                 *Worth Lutz*
>>                 On 06/22/2016 02:06 PM, Vicky Vergara wrote:
>>>                 Tell when you make the branch
>>>                 so I can pinpoint where to find the docuemtnation
>>>                 On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz
>>>                 wrote:
>>>                     Thanks Vicky.  I'll let you know what I find.
>>>                     *Worth Lutz*
>>>                     On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>>>>                     Hello Worth Lutz.
>>>>                     The documentation changes you made them to
>>>>                     master or to develop?
>>>>                     Right now develop documentation has changed,
>>>>                     not in everything put it has lots of changes.
>>>>                     http://docs.pgrouting.org/dev/en/doc/index.html
>>>>                     It is better for us to work on the develop
>>>>                     branch which has the 2.3 documentation.
>>>>                     Its changing a lot. so to have the current
>>>>                     contents of develop in your for:
>>>>                     git checkout develop
>>>>                     git fetch upstream
>>>>                     git merge upstream/develop
>>>>                     git push
>>>>                     then in the github site you will be able to see
>>>>                     that it contains the current contents of develop.
>>>>                     Then you can branch to a working directory
>>>>                     git checkout -b 'improve/documentation'
>>>>                     then do a
>>>>                     git push
>>>>                     and give me the link to the branch in your
>>>>                     repository so that if I make changes to
>>>>                     develop's documentation, I can make a pull
>>>>                     request to your branch with the changes I made.
>>>>                     Work on the documentation, and make pull
>>>>                     requests to develop.
>>>>                     thanks.
>>>>                     Vicky from the pgRouting team
>>>>                     On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz
>>>>                         If I want to work on some errors/typos in
>>>>                         the documentation, how do I do that?
>>>>                         I've got a fork and want to create a pull
>>>>                         request.
>>>>                         Which branch should I be working on?
>>>>                         As I'm starting a new routing project, I'm
>>>>                         reading (and rereading) the documentation a
>>>>                         lot and think I should fix what I find.
>>>>                         *Worth Lutz*
>>>>                         _______________________________________________
>>>>                         pgrouting-dev mailing list
>>>>                         pgrouting-dev at lists.osgeo.org
>>>>                         <mailto:pgrouting-dev at lists.osgeo.org>
>>>>                         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>>>                     Georepublic UG (haftungsbeschränkt)
>>>>                     Salzmannstraße 44,
>>>>                     81739 München, Germany
>>>>                     Vicky Vergara
>>>>                     Operations Research
>>>>                     eMail: vicky at georepublic.de <http://georepublic.de>
>>>>                     Web:https://georepublic.info
>>>>                     Tel: +49 (089) 4161 7698-1
>>>>                     Fax: +49 (089) 4161 7698-9
>>>>                     Commercial register: Amtsgericht München, HRB 181428
>>>>                     CEO: Daniel Kastl
>>>                 Salzmannstraße 44,
>>>                 Vicky Vergara
>>>                 Operations Research
>>>                 CEO: Daniel Kastl
>>             Salzmannstraße 44,
>>             Vicky Vergara
>>             Operations Research
>>             CEO: Daniel Kastl
>>         Salzmannstraße 44,
>>         Vicky Vergara
>>         Operations Research
>>         CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160710/bd40c20f/attachment-0001.html>
More information about the pgrouting-dev mailing list
