[pgrouting-dev] How do I work on pgRouting documentation?
Worth Lutz wal3 at mindspring.com
Wed Jun 22 10:58:19 PDT 2016
Thanks Vicky.  I'll let you know what I find.
*Worth Lutz*
On 6/22/2016 1:53 PM, Vicky Vergara wrote:
> Hello Worth Lutz.
> The documentation changes you made them to master or to develop?
> Right now develop documentation has changed, not in everything put it
> has lots of changes.
> http://docs.pgrouting.org/dev/en/doc/index.html
> It is better for us to work on the develop branch which has the 2.3
> documentation.
> Its changing a lot. so to have the current contents of develop in your
> for:
> git checkout develop
> git fetch upstream
> git merge upstream/develop
> git push
> then in the github site you will be able to see that it contains the
> current contents of develop.
> Then you can branch to a working directory
> git checkout -b 'improve/documentation'
> then do a
> git push
> and give me the link to the branch in your repository so that if I
> make changes to develop's documentation, I can make a pull request to
> your branch with the changes I made.
> Work on the documentation, and make pull requests to develop.
> thanks.
> Vicky from the pgRouting team
> On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz <wal3 at mindspring.com
> <mailto:wal3 at mindspring.com>> wrote:
>     If I want to work on some errors/typos in the documentation, how
>     do I do that?
>     I've got a fork and want to create a pull request.
>     Which branch should I be working on?
>     As I'm starting a new routing project, I'm reading (and rereading)
>     the documentation a lot and think I should fix what I find.
>     *Worth Lutz*
>     _______________________________________________
>     pgrouting-dev mailing list
>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de <http://georepublic.de>
> Web:https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160622/abcaf88b/attachment-0001.html>
More information about the pgrouting-dev mailing list
