[pgrouting-dev] How do I work on pgRouting documentation?
Vicky Vergara vicky at georepublic.de
Wed Jun 22 11:06:13 PDT 2016
Tell when you make the branch
so I can pinpoint where to find the docuemtnation
On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz <wal3 at mindspring.com> wrote:
> Thanks Vicky.  I'll let you know what I find.
> *Worth Lutz*
> On 6/22/2016 1:53 PM, Vicky Vergara wrote:
> Hello Worth Lutz.
> The documentation changes you made them to master or to develop?
> Right now develop documentation has changed, not in everything put it has
> lots of changes.
> http://docs.pgrouting.org/dev/en/doc/index.html
> It is better for us to work on the develop branch which has the 2.3
> documentation.
> Its changing a lot. so to have the current contents of develop in your for:
> git checkout develop
> git fetch upstream
> git merge upstream/develop
> git push
> then in the github site you will be able to see that it contains the
> current contents of develop.
> Then you can branch to a working directory
> git checkout -b 'improve/documentation'
> then do a
> git push
> and give me the link to the branch in your repository so that if I make
> changes to develop's documentation, I can make a pull request to your
> branch with the changes I made.
> Work on the documentation, and make pull requests to develop.
> thanks.
> Vicky from the pgRouting team
> On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz <wal3 at mindspring.com> wrote:
>> If I want to work on some errors/typos in the documentation, how do I do
>> that?
>> I've got a fork and want to create a pull request.
>> Which branch should I be working on?
>> As I'm starting a new routing project, I'm reading (and rereading) the
>> documentation a lot and think I should fix what I find.
>> *Worth Lutz*
>> pgrouting-dev mailing list
>> pgrouting-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
> pgrouting-dev mailing listpgrouting-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160622/9bdc142b/attachment.html>
More information about the pgrouting-dev mailing list
