[pgrouting-dev] How do I work on pgRouting documentation?
Worth Lutz wal3 at mindspring.com
Wed Jun 22 12:10:46 PDT 2016
Vicky,
My github is at:
     https://github.com/worthlutz/pgrouting/
The branch I'll be using is *doc-improvements* branched off *develop*.
I'll let you know when I push some changes.
*Worth Lutz*
On 06/22/2016 02:06 PM, Vicky Vergara wrote:
> Tell when you make the branch
> so I can pinpoint where to find the docuemtnation
> On Wed, Jun 22, 2016 at 12:58 PM, Worth Lutz <wal3 at mindspring.com
> <mailto:wal3 at mindspring.com>> wrote:
>     Thanks Vicky.  I'll let you know what I find.
>     *Worth Lutz*
>     On 6/22/2016 1:53 PM, Vicky Vergara wrote:
>>     Hello Worth Lutz.
>>     The documentation changes you made them to master or to develop?
>>     Right now develop documentation has changed, not in everything
>>     put it has lots of changes.
>>     http://docs.pgrouting.org/dev/en/doc/index.html
>>     It is better for us to work on the develop branch which has the
>>     2.3 documentation.
>>     Its changing a lot. so to have the current contents of develop in
>>     your for:
>>     git checkout develop
>>     git fetch upstream
>>     git merge upstream/develop
>>     git push
>>     then in the github site you will be able to see that it contains
>>     the current contents of develop.
>>     Then you can branch to a working directory
>>     git checkout -b 'improve/documentation'
>>     then do a
>>     git push
>>     and give me the link to the branch in your repository so that if
>>     I make changes to develop's documentation, I can make a pull
>>     request to your branch with the changes I made.
>>     Work on the documentation, and make pull requests to develop.
>>     thanks.
>>     Vicky from the pgRouting team
>>     On Wed, Jun 22, 2016 at 12:10 PM, Worth Lutz <wal3 at mindspring.com
>>         If I want to work on some errors/typos in the documentation,
>>         how do I do that?
>>         I've got a fork and want to create a pull request.
>>         Which branch should I be working on?
>>         As I'm starting a new routing project, I'm reading (and
>>         rereading) the documentation a lot and think I should fix
>>         what I find.
>>         *Worth Lutz*
>>         _______________________________________________
>>         pgrouting-dev mailing list
>>         pgrouting-dev at lists.osgeo.org
>>         <mailto:pgrouting-dev at lists.osgeo.org>
>>         http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>     Georepublic UG (haftungsbeschränkt)
>>     Salzmannstraße 44,
>>     81739 München, Germany
>>     Vicky Vergara
>>     Operations Research
>>     eMail: vicky at georepublic.de <http://georepublic.de>
>>     Web:https://georepublic.info
>>     Tel: +49 (089) 4161 7698-1
>>     Fax: +49 (089) 4161 7698-9
>>     Commercial register: Amtsgericht München, HRB 181428
>>     CEO: Daniel Kastl
>>     pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20160622/faf1525b/attachment.html>
More information about the pgrouting-dev mailing list
