[pgrouting-dev] libCGAL.so.11() not found while installing pgRouting
wolfgang.ganzert at stihl.de wolfgang.ganzert at stihl.de
Wed Dec 13 04:43:57 PST 2017
Hello Vicky,
Thank You for the reply.
Although pgRouting 2.0.1 is quite old we decided to install this version because we found some recipe for Centos 7 to install a local OSM server. If we would opt for a newer version we probably would run into unfulfilled dependencies with some basic OS libs.
Regarding libCGAL we took version 4.7 and the dependencies are okay.
I will let You know if in the end everything works fine.
Best regards
Wolfgang
From: pgrouting-dev [mailto:pgrouting-dev-bounces at lists.osgeo.org] On Behalf Of Vicky Vergara
Sent: Friday, December 8, 2017 9:29 PM
To: pgRouting developers mailing list <pgrouting-dev at lists.osgeo.org>
Subject: Re: [pgrouting-dev] libCGAL.so.11() not found while installing pgRouting
Hello,
I see you are trying to install pgRouting version 2.0.1 (which is basically 2.0.0 so its like 4 years old.
Our latest version is 2.5.2
I don't know Centos at all, but I see there is no package for postgreSQL 9.4 & pgRouting 2.5.2
But there are for 9.5, 9.6 and 10
https://yum.postgresql.org/packages.php
For example:
https://yum.postgresql.org/10/redhat/rhel-7-x86_64/repoview/pgrouting_10.html
If you say that you are a beginner and starting to make your server, why don't you use postgreSQL version 10, that would give you a 5 year range before its EOL
https://www.postgresql.org/support/versioning/
The other option I can think of, is to compile and install it yourself.
Vicky
On Fri, Dec 8, 2017 at 6:01 AM, <wolfgang.ganzert at stihl.de<mailto:wolfgang.ganzert at stihl.de>> wrote:
Hello,
Please excuse my questions but I’m a totally beginner in setting up a local OSM server on CentOS 7.3.
However I managed to have a few things done but now I have a question.
Since there were not all libs and programs for CentOS 7.3 available I followed a recipe from the internet describing how to set-up an OSM sever on CentOS 7.3.
For pgRouting I needed to build the libCGAL myself which I did and I got a libCGAL.so.11 after cmake / make. I used the sources 4.6.1 for libCGAL.
After running make install the libraries were installed in the directory /usr/local/lib which is kind of strange because CentOS is solely x86_64.
When installing pgRouting witch yum localinstall  pgrouting_94-2.0.1-2.rhel7.x86_64.rpm the installation is always complaining that a dependency is not fulfilled for libCGAL.so.11.
Could you please give me a hint how to solve this?
Thank You in advance and kind regards
Wolfgang
ANDREAS STIHL AG & Co. KG
Kommanditgesellschaft mit Sitz in Waiblingen, HRA 260269, Amtsgericht Stuttgart
Persönlich haftende Gesellschafter: Hans Peter Stihl und STIHL Aktiengesellschaft mit Sitz in Waiblingen, HRB 263722, Amtsgericht Stuttgart
Vorstand der STIHL AG: Dr. Bertram Kandziora (Vorstandsvorsitzender), Karl Angler, Norbert Pick, Dr. Michael Prochaska, Wolfgang Zahn
Vorsitzender des Aufsichtsrats der STIHL AG: Dr. Nikolas Stihl
____________________________________________________________________________
Wenn Sie nicht der rechtmäßige Empfänger sind, senden Sie uns bitte die E-Mail zurück
und löschen Sie sie auf Ihrem System. Die unberechtigte Nutzung oder Weitergabe von
vertraulichen Informationen kann strafrechtlich und zivilrechtlich verfolgt werden.
If you are not the legitimate recipient, please send the e-mail back and delete it
on your system. Any unauthorized use or transfer of confidential information
may have legal consequences.
pgrouting-dev mailing list
pgrouting-dev at lists.osgeo.org<mailto:pgrouting-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de<http://georepublic.de>
Web: https://georepublic.info
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20171213/5fd56de8/attachment-0001.html>
More information about the pgrouting-dev mailing list
