[pgrouting-dev] [Incubator] Incubate pgRouting as OSGeo Project
Vicky Vergara vicky at georepublic.de
Fri Aug 12 10:35:41 PDT 2022
Hello Incubator committee,
Just as a reminder we made a request for funding:
https://lists.osgeo.org/pipermail/incubator/2022-January/004454.html
Regards
On Wed, Aug 10, 2022 at 7:10 PM Vicky Vergara <vicky at georepublic.de> wrote:
> Hi Incubator committee,
> Yes we do have a mentor.
> Angelos Tzotsos.
> Regards
> Note: The WIP questionnaire does have the question about the mentor.
> On Wed, Aug 10, 2022 at 1:37 AM Jody Garnett <jody.garnett at gmail.com>
> wrote:
>> Wow that is great,
>> Thanks for the application.
>> Did you have a mentor or mind? Or can you reach out to the osgeo
>> community for a volunteer?
>> Jody
>> On Tue, Jul 26, 2022 at 10:52 AM Vicky Vergara <vicky at georepublic.de>
>> wrote:
>>> Hello committee:
>>> The incubation questionnaire can be found on [4]
>>> Regards
>>> [4] https://trac.osgeo.org/osgeo/ticket/2784
>>> On Tue, Jul 26, 2022 at 10:35 AM Vicky Vergara <vicky at georepublic.de>
>>>> We are making a formal request to the incubation committee to incubate pgRouitng.
>>>> We have read the [1], [2] and [3] and we think that most of the points as most, if not all, are already done for pgRouting.
>>>> From [1] pgROuting fulfils all the requirements to make the application:
>>>>    - geospatial: pgRouting is a library that helps solve geospatial
>>>>    problems, routing in particular.
>>>>    - open source license: pgRouting is under GPLv2 for the code, and CC
>>>>    BY-SA 3.0 for the documentation.
>>>>    - accepts contributions: pgRouting accepts contributions from
>>>>    documentation and bug fixes, up to creation of new functionality.
>>>>    - source code check, with source code audit: all of pgRouting's PR
>>>>    needs to be reviewed.
>>>>    - open community with transparent communication and decision making
>>>>    process: pgRouting has 2 mailing lists, a gitter chat and an IRC channel.
>>>>    - active and healthy community with user and developer
>>>>    collaboration, drawing members from several organizations for long term
>>>>    viability: pgRouting has this large range of contributors.
>>>>    - development supported by version control and issue tracker:
>>>>    pgRouting uses github.
>>>>    - developer leadership offering both transparent decision making
>>>>    and an opportunity for new members to participate: pgRouting uses the
>>>>    communication tools to promote this.
>>>>    - user documentation and developer documentation: pgRouting has both
>>>>    - release procedure covering both the release process and
>>>>    documented testing process: We have both, a procedure document, and the
>>>>    tests are carried out on github actions.
>>>> In the next mail, the link to the questionnaire [2] on a trac ticket will be given.
>>>> Thanks.
>>>> [1] https://www.osgeo.org/about/committees/incubation/
>>>> [2] https://www.osgeo.org/about/committees/incubation/application/
>>>> [3] https://www.osgeo.org/wp-content/uploads/graduation_checklist.pdf
>>>> Georepublic UG (haftungsbeschränkt)Salzmannstraße 44,
>>>> 81739 München, Germany <https://www.google.com/maps/search/Salzmannstra%C3%9Fe+44,+%0D%0A81739+M%C3%BCnchen,+Germany?entry=gmail&source=g>
>>>> Vicky Vergara
>>>> Operations Research
>>>> eMail: vicky at georepublic.de
>>>> Web: https://georepublic.info
>>>> Tel: +49 (089) 4161 7698-1
>>>> Fax: +49 (089) 4161 7698-9
>>>> Commercial register: Amtsgericht München, HRB 181428
>>>> CEO: Daniel Kastl
>>> Vicky Vergara
>>> Operations Research
>>> CEO: Daniel Kastl
>>> Incubator mailing list
>>> Incubator at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/incubator
> Salzmannstraße 44,
> Vicky Vergara
> Operations Research
> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220812/d7d12279/attachment.htm>
More information about the pgrouting-dev mailing list
