[pgrouting-dev] [Incubator] Incubate pgRouting as OSGeo Project
Vicky Vergara vicky at georepublic.de
Wed Aug 10 17:10:43 PDT 2022
Hi Incubator committee,
Yes we do have a mentor.
Angelos Tzotsos.
Regards
Note: The WIP questionnaire does have the question about the mentor.
On Wed, Aug 10, 2022 at 1:37 AM Jody Garnett <jody.garnett at gmail.com> wrote:
> Wow that is great,
> Thanks for the application.
> Did you have a mentor or mind? Or can you reach out to the osgeo community
> for a volunteer?
> Jody
> On Tue, Jul 26, 2022 at 10:52 AM Vicky Vergara <vicky at georepublic.de>
> wrote:
>> Hello committee:
>> The incubation questionnaire can be found on [4]
>> Regards
>> [4] https://trac.osgeo.org/osgeo/ticket/2784
>> On Tue, Jul 26, 2022 at 10:35 AM Vicky Vergara <vicky at georepublic.de>
>> wrote:
>>> Hello Incubator committee,
>>> We are making a formal request to the incubation committee to incubate pgRouitng.
>>> We have read the [1], [2] and [3] and we think that most of the points as most, if not all, are already done for pgRouting.
>>> From [1] pgROuting fulfils all the requirements to make the application:
>>>    - geospatial: pgRouting is a library that helps solve geospatial
>>>    problems, routing in particular.
>>>    - open source license: pgRouting is under GPLv2 for the code, and CC
>>>    BY-SA 3.0 for the documentation.
>>>    - accepts contributions: pgRouting accepts contributions from
>>>    documentation and bug fixes, up to creation of new functionality.
>>>    - source code check, with source code audit: all of pgRouting's PR
>>>    needs to be reviewed.
>>>    - open community with transparent communication and decision making
>>>    process: pgRouting has 2 mailing lists, a gitter chat and an IRC channel.
>>>    - active and healthy community with user and developer
>>>    collaboration, drawing members from several organizations for long term
>>>    viability: pgRouting has this large range of contributors.
>>>    - development supported by version control and issue tracker:
>>>    pgRouting uses github.
>>>    - developer leadership offering both transparent decision making and
>>>    an opportunity for new members to participate: pgRouting uses the
>>>    communication tools to promote this.
>>>    - user documentation and developer documentation: pgRouting has both
>>>    - release procedure covering both the release process and documented
>>>    testing process: We have both, a procedure document, and the tests are
>>>    carried out on github actions.
>>> In the next mail, the link to the questionnaire [2] on a trac ticket will be given.
>>> Thanks.
>>> [1] https://www.osgeo.org/about/committees/incubation/
>>> [2] https://www.osgeo.org/about/committees/incubation/application/
>>> [3] https://www.osgeo.org/wp-content/uploads/graduation_checklist.pdf
>>> Georepublic UG (haftungsbeschränkt)Salzmannstraße 44,
>>> 81739 München, Germany <https://www.google.com/maps/search/Salzmannstra%C3%9Fe+44,+%0D%0A81739+M%C3%BCnchen,+Germany?entry=gmail&source=g>
>>> Vicky Vergara
>>> Operations Research
>>> eMail: vicky at georepublic.de
>>> Web: https://georepublic.info
>>> Tel: +49 (089) 4161 7698-1
>>> Fax: +49 (089) 4161 7698-9
>>> Commercial register: Amtsgericht München, HRB 181428
>>> CEO: Daniel Kastl
>> Vicky Vergara
>> Operations Research
>> CEO: Daniel Kastl
>> Incubator mailing list
>> Incubator at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/incubator
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20220810/df6422f0/attachment.htm>
More information about the pgrouting-dev mailing list
