[pgrouting-users] [Fwd: Debian Lenny: compatibility between libcgal-dev and libboost1.35-dev]
Stephen Woodbridge woodbri at swoodbridge.com
Thu Aug 6 14:39:52 EDT 2009
FYI. I sent this off today.
Not sure if anyone is using debian/lenny here other than me.
I provide an update, if there is any interesting news. I have pgRouting
installed on another lenny box using Boost 1.34.1 but there does not
appear to be a gaul library for debian. :(  So no TSP or DD.
-Steve
-------- Original Message --------
Subject: Debian Lenny: compatibility between  libcgal-dev and
libboost1.35-dev
Date: Thu, 06 Aug 2009 14:02:50 -0400
From: Stephen Woodbridge <woodbri at swoodbridge.com>
To: Joachim Reichel <joachim.reichel at gmx.de>,  Debian Boost Team
<pkg-boost-devel at lists.alioth.debian.org>
Hello Joachim, and The Boost Packaging Team,
I'm running Debian Lenny on an amd64 box and I needed to load
libcgal-dev to build pgRouting application. I have been using
libboost1.35-dev and see that the packaging is broken if I try to
install libcgal-dev.
I might be able to backup to libboost 1.34.1, but it would be nice if
libcgal would install on the newer version. I realize this might be an
issue also with the boost team with respect to package names and
version, but maybe you guys can work this out so users like me don't get
tripped up by this problem.
Thank you both for your efforts, they are all appreciated.
Best regards,
   -Steve
More information about the Pgrouting-users mailing list
