[pgrouting-users] [Fwd: Debian Lenny: compatibility between libcgal-dev and libboost1.35-dev]
Daniel Kastl kastl at orkney.co.jp
Thu Aug 6 20:59:00 EDT 2009
Hi Steve,
Well, I have a server with Debian but not with pgRouting ... probably
this is one reason.
I agree that those dependencies are always a pain. Gaul doesn't come as
a package, CGAL has a weired license. Actually both of them are just
used for little parts, so it would be nice to be able to get rid of them
... which requires some sort of sponsorship then if there is no
volunteer (same problem with Windows binaries by the way referencing to
the discussion on the PostGIS mailing list last night)
Daniel
Stephen Woodbridge schrieb:
> FYI. I sent this off today.
> Not sure if anyone is using debian/lenny here other than me.
> I provide an update, if there is any interesting news. I have pgRouting
> installed on another lenny box using Boost 1.34.1 but there does not
> appear to be a gaul library for debian. :(  So no TSP or DD.
> -Steve
> -------- Original Message --------
> Subject: Debian Lenny: compatibility between  libcgal-dev and
> libboost1.35-dev
> Date: Thu, 06 Aug 2009 14:02:50 -0400
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> To: Joachim Reichel <joachim.reichel at gmx.de>,  Debian Boost Team
> <pkg-boost-devel at lists.alioth.debian.org>
> Hello Joachim, and The Boost Packaging Team,
> I'm running Debian Lenny on an amd64 box and I needed to load
> libcgal-dev to build pgRouting application. I have been using
> libboost1.35-dev and see that the packaging is broken if I try to
> install libcgal-dev.
> I might be able to backup to libboost 1.34.1, but it would be nice if
> libcgal would install on the newer version. I realize this might be an
> issue also with the boost team with respect to package names and
> version, but maybe you guys can work this out so users like me don't get
> tripped up by this problem.
> Thank you both for your efforts, they are all appreciated.
> Best regards,
>    -Steve
> Pgrouting-users mailing list
> Pgrouting-users at lists.postlbs.org
> http://lists.postlbs.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
