[pgrouting-users] [Fwd: [mapserver-users] Re: OpenStreetMap + osm2pgsql = pgRouting]
Stephen Woodbridge woodbri at swoodbridge.com
Mon May 17 21:11:30 EDT 2010
This is probably because the OSM data is not properly noded at all
intersections. For example, this is bad for routing:
         C
A------------------B
         D
In the example above lines AB and CD cross.
         C
         |E
A-------+----------B
         D
For routing you need a node E at the intersection with segments:
AE, EB, CE, DE
This has bee discussed on the list, you might also check the archives
for the postGIS list or post a message there on how to fix your data.
-Steve
  http://imaptools.com/
-------- Original Message --------
Subject: [mapserver-users] Re: OpenStreetMap + osm2pgsql = pgRouting
Date: Mon, 17 May 2010 15:00:46 -0700 (PDT)
To: mapserver-users at lists.osgeo.org
References: <1274130822829-5067095.post at n2.nabble.com>
Looking further into the matter,
i have noticed that the only cases where i have managed to get some result
with the shortest_path function is when there is a straight line between A
and B, but if i need to do A and C, and there is no straight line between
them (suppose something like A => B => C), then no result will be returned
The same applies for other routing algorithms ... and still no clue
View this message in context:
http://osgeo-org.1803224.n2.nabble.com/OpenStreetMap-osm2pgsql-pgRouting-tp5067095p5067309.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the Pgrouting-users mailing list
