[pgrouting-users] Re: Pgrouting-users Digest, Vol 29, Issue 2
Cleber Arruda cleverdo at gmail.com
Wed Feb 2 02:46:54 EST 2011
Thanks Adil,
I will take a look on it and let see what I will come up with.
Merci
Cleber
P.S. I will keep in touch if I have any doubt if you don't mind.
On Tue, Feb 1, 2011 at 7:12 PM, <pgrouting-users-request at lists.osgeo.org>wrote:
> Send Pgrouting-users mailing list submissions to
>        pgrouting-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>        http://lists.osgeo.org/mailman/listinfo/pgrouting-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>        pgrouting-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Pgrouting-users digest..."
> Today's Topics:
>   1. Re : [pgrouting-users] pgrouting - Driving Direction -
>      foss4g2010,       WORKSHOP (Adil BOUMAZOUED)
> Message: 1
> Date: Tue, 1 Feb 2011 18:12:10 +0000
> From: Adil BOUMAZOUED <boumazoued at gmail.com>
> Subject: Re : [pgrouting-users] pgrouting - Driving Direction -
> To: pgrouting-users at lists.osgeo.org
> Message-ID:
>        <AANLkTimHofmC6TXUgSP-W3pw4DnM8XK9Y+Bb1kb1K8rP at mail.gmail.com<AANLkTimHofmC6TXUgSP-W3pw4DnM8XK9Y%2BBb1kb1K8rP at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> hi,
> i hope this code can help you. it s not complete and not optimised
> <html xmlns="http://www.w3.org/1999/xhtml">
> <?php
> if ( extension_loaded('pgsql') != 1)
>    switch (PHP_OS)
>  case "WINNT": if (!extension_loaded('pgsql'))  dl("php_pgsql.dll");
>                    break;
>      default:  if (!extension_loaded('pgsql'))  dl("php_pgsql.so");
>               break;
> // includes du fichier fonctions
> require 'connexion.php';
> function ConvertTemps ($temps) {
> if ($temps<60) {
> $temps=round($temps,0);
> $msg= $temps.'s';
> if ($temps>=60 && $temps<3600) {
> $temps_s=$temps % 60;
> $temps_mn = ($temps - $temps_s)/60;
> $msg= $temps_mn.'mn'.$temps_s.'s';
> if ($temps>=3600) {
> $temps_s=$temps % 3600;
> $temps_h=($temps - $temps_s)/3600;
> if ($temps_s>=60) {
> $msg= $temps_h.'h'.$temps_mn.'mn'.$temps_s.'s';
> } else {
> $msg= $temps_h.' h00mn '.$temps_s.'s';
> return $msg;
> function ConvertDistance ($longueur) {
> $longueur=round($longueur,0);
> if ($longueur>=1000) {
> $longueur = round($longueur,0);
> $longueur_metre=$longueur % 1000;
> $longueur_km = ($longueur - $longueur_metre)/1000;
> $msg= $longueur_km.'km'.$longueur_metre.'m';
> } else {
> $msg= $longueur.'m';
> return $msg;
> function direction($x1,$y1,$x2,$y2,$x3,$y3,$x4,$y4,$typ)
> $pi=pi();
> $Gisement=100000;
> $Gisement1=100000;
> $dx=1000000*($x2-$x1);
> $dy=1000000*($y2-$y1);
> if (($dx==0)&&($dy==0))
> $Gisement=0;
> if (($dy==0)&&($dx>0))
> $Gisement=100;
> if (($dy==0)&&($dx<0))
> $Gisement=300;
> if (($Gisement!=0)&&($Gisement!=100)&&($Gisement!=300))
> $di = atan(abs($dx/$dy))*200/$pi;
> if (($dx>=0)&&($dy<0)) {
> $di=200-$di;
>  if (($dx<=0)&&($dy<0)) {
> $di=200+$di;
>  if (($dx<=0)&&($dy>0)) {
> $di=400-$di;
>  $Gisement=$di;
> $dx=1000000*($x3-$x4);
> $dy=1000000*($y3-$y4);
> $Gisement1=0;
> $Gisement1=100;
> $Gisement1=300;
> if (($Gisement1!=0)&&($Gisement1!=100)&&($Gisement1!=300))
> $di=200-$di;
> $di=200+$di;
> $di=400-$di;
> $Gisement1=$di;
> $g21=$Gisement;
> $g23=$Gisement1;
> $dir=-$g23+$g21+200;
> if ($dir>200) {
> $dir = $dir-400;
> if ($dir<-200) {
> $dir = $dir+400;
> if ($dir>=-10 AND $dir<=10) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/21.gif> Continuer tout
> droit";
> if ($dir>=-50 AND $dir<-10) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/22.gif> Serrer à droite";
> if ($dir>=-110 AND $dir<-50) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/22.gif> Tourner à droite";
> if ($dir>=-150 AND $dir<-100) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/22.gif>Tourner trop serrer à
> droite";
> if ($dir>=-200 AND $dir<-150) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/22.gif>Faite demi tour à
> droite";
> if ($dir>10 AND $dir<=50) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/24.gif>Serrer à gauche";
> if ($dir>50 AND $dir<=110) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/24.gif>Tourner à gauche";
> if ($dir>110 AND $dir<=150) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/24.gif>Tourner trop serrer à
> gauche";
> if ($dir>150 AND $dir<=200) {
> $msg="<IMG width=32 height=32 SRC=img/roadmap/24.gif>Faite demi tour à
> gauche";
>  if($typ==1)
> $msg="<IMG width=32 height=32 SRC=img/roadmap/10.gif> Prendre le Rond Point
> RETURN $msg;
>  $counter = $pathlength = 0;
>  // Retrieve start point
>  $start = split(' ',$_REQUEST['startpoint']);
>  $startPoint1 = array($start[0], $start[1]);
> $txtStart = $_REQUEST['txtstartpoint'];
> $txtEnd = $_REQUEST['txtendpoint'];
>  //echo $_REQUEST['startpoint'];
>  // Retrieve end point
>  $end = split(' ',$_REQUEST['finalpoint']);
>  $endPoint1 = array($end[0], $end[1]);
> //echo $_REQUEST['finalpoint'];
>  // Find the nearest edge
>  $startEdge = findNearestEdge($startPoint1);
>  $endEdge   = findNearestEdge($endPoint1);
>  // FUNCTION findNearestEdge
>  function findNearestEdge($lonlat) {
>    // Connect to database
>  $con  = pg_connect("host=".PG_HOST."
>                        dbname=".PG_DB."
>                        user=".PG_USER."
>                        password=".PG_PASSWORD."");
>    //$con = pg_connect("dbname=".PG_DB." host=".PG_HOST." user=".PG_USER."
> password=".PG_PASSWORD);
>    $sql = "SELECT gid, source, target, the_geom,
>  distance(the_geom, GeometryFromText(
>                  'POINT(".$lonlat[0]." ".$lonlat[1].")', -1)) AS dist
>            FROM ".TABLE."
>            WHERE the_geom && setsrid(
>                  'BOX3D(".($lonlat[0]-0.1)."
>                         ".($lonlat[1]-0.1).",
>                         ".($lonlat[0]+0.1)."
>                         ".($lonlat[1]+0.1).")'::box3d, -1)
>            ORDER BY dist LIMIT 1";
>  //echo $sql;
>    $query = pg_query($con,$sql);
>    $edge['gid']      = pg_fetch_result($query, 0, 0);
>    $edge['source']   = pg_fetch_result($query, 0, 1);
>    $edge['target']   = pg_fetch_result($query, 0, 2);
>    $edge['the_geom'] = pg_fetch_result($query, 0, 3);
>    // Close database connection
>    pg_close($con);
>    return $edge;
>  // Select the routing algorithm
>  switch($_REQUEST['method']) {
>    case 'SPD' : // Shortest Path Dijkstra
>      $sql = "SELECT rt.gid, AsText(rt.the_geom) AS wkt,
>                   length(rt.the_geom) AS length, ".TABLE.".id
>                FROM ".TABLE.",
>                    (SELECT gid, the_geom
>                        FROM dijkstra_sp_delta(
>                            '".TABLE."',
>                            ".$startEdge['source'].",
>                            ".$endEdge['target'].",
>                            0.01)
>                     ) as rt
>                WHERE ".TABLE.".gid=rt.gid;";
>      break;
>    case 'SPA' : // Shortest Path A*
>                     ".TABLE.".length, ".TABLE.".id, ".TABLE.".temps,
> ".TABLE.".on, ".TABLE.".typ, ".TABLE.".id ,  ".TABLE.".x1 as xs,
>  ".TABLE.".y1 as ys,  ".TABLE.".x2 as xe,  ".TABLE.".y2 as ye
>                  FROM ".TABLE.",
>                      (SELECT *
>                          FROM astar_sp_delta(
>                              '".TABLE."',
>                              0.01)
>                       ) as rt
>      break;
>    case 'SPS' : // Shortest Path Shooting*
> if ($_REQUEST['mode']==1) {
>                     length(rt.the_geom) AS length, rt.length, rt.temps,
> rt.on, rt.typ, ".TABLE.".id , rt.xs, rt.ys, rt.xe, rt.ye
>                  FROM ".TABLE.",
>                      (SELECT a.gid, a.the_geom, b.temps, b.on, b.typ ,
> b.length as length, b.x1 as xs, b.y1 as ys, b.x2 as xe, b.y2 as ye
>                          FROM shootingstar_sp(
>                              '".TABLE."',
>                              ".$startEdge['gid'].",
>                              ".$endEdge['gid'].",
>                              0.01, 'length',true, false) a, roads b where
> a.gid=b.gid
>                       ) as rt
>  } else {
>                  FROM ".TABLE.",
>                              '".TABLE."',
>                              0.01, 'temps',true, false) a, roads b where
> a.gid=b.gid
>                       ) as rt
>  break;
>  } // close switch
> //echo $sql;
>  // Database connection and query
>  $dbcon = pg_connect("host=".PG_HOST."
>                        dbname=".PG_DB."
>                        user=".PG_USER."
>  $query = pg_query($dbcon,$sql);
>  // Return route as html table
> $xml1  .= "<style type='text/css'>";
> $xml1  .= "a:link {";
> $xml1  .= " color: #FFCC00;";
> $xml1  .= "}";
> $xml1  .= "a:visited {";
> $xml1  .= "}";
> $xml1  .= ".style1 {font-size: 12px;font-family: Verdana, Arial, Helvetica,
> sans-serif;font-weight: bold;}";
> $xml1  .= ".style2 {font-family: Verdana, Arial, Helvetica,
> sans-serif;font-size: 12px;}";
> $xml1  .= ".style3 {color: #808080}";
> $xml1  .= "</style>";
> echo $xml1;
> //echo "depart ".$startEdge['gid']." -------<p>";
> $xml .= "sql=".$sql." fin de la requête";
>  $xml .= "<table width='100%' border='2' cellpadding='0' cellspacing='1'
> bordercolor='#FF9F00' bgcolor='#FFFFFF'>";
>  $xml .="<tr bordercolor='#C0C0C0'>";
>  $xml .= "<td><strong>Etape</strong></td>";
>  $xml .= "<td><strong>Id Tronçon</strong></td>";
>  $xml .= "<td><strong>length Etape</strong></td>";
>  $xml .= "<td><strong>length Cumulé</strong></td>";
>  $xml .= "<td><strong>Temps moyen</strong></td>";
>  $xml .= "<td><strong>Nom de la Rue</strong></td>";
>  $xml .="</tr>";
>  // Add edges to XML file
>  while($edge=pg_fetch_assoc($query)) {
>    $pathlength += $edge['length'];
>    $xml .= "<td> ".++$counter."</td>";
>    $xml .= "<td> ".$edge['gid']."</td>";
> //déclaration des tableaux pour organisation de la feuille du route
> $ii[$counter] = $edge['gid'];
> $startPoint[$counter] = array($edge['xs'], $edge['ys']);
> $endPoint[$counter] = array($edge['xe'], $edge['ye']);
> $rue[$counter] = $edge['on'];
> $x1[$counter] = $edge['xs'];
> $y1[$counter] = $edge['ys'];
> $x2[$counter] = $edge['xe'];
> $y2[$counter] = $edge['ye'];
> $length[$counter]=$edge['length'];
> $temps[$counter]=3600*40/(1000*$edge['length']);
> $type[$counter]=$edge['typ'];
> //fin des déclaration
> $temps1=3600*40/(1000*$edge['length']);
> $temps_trajet +=$temps1;
> if ($temps1>60) {
> $temps1=$temps1/60;
> $temps2=round($temps1,0)." mn";
> if ($temps1>3600) {
> $temps1=$temps1/3660;
> $temps2=round($temps1,0)." h";
> if ($temps1<60) {
> $temps1=$temps1;
> $temps2=round($temps1,0)." s";
> $xml .= "<td> ".round($edge['length'],2)." m</td>";
>    $xml .= "<td> ".round(($pathlength),2)." m</td>";
> $xml .= "<td> ".$edge['wkt']."</td>";
> //pour vérifier le changement du rue par son nom
> $on[$i+1]=$edge['on'];
> $j = $i;
> $i +=1;
> if ($on[$i] != $on[$j])
> $xml .= "<td> <img src='img/roadmap/2.png'>".$edge['on'].".</td>";
> else {
> $xml .= "<td> ".$edge['on'].".</td>";
> $xml .="</tr>";
>  $xml .= "</table>";
>  pg_close($dbcon);
> echo "<h3 style='color:#2e585c;'>Feuille de route</h3>";
>  // Return routing result
>  //header('Content-type: text/xml',true);
> echo "<div style='width:250px; float:left; border-left:1px solid #CCCCCC;
>  border-right:1px solid #CCCCCC; padding:0 10px;'>";
> echo "<span class='style3'>".htmlentities("Résumé du
> Trajet")."</span><br>";
> if ($_REQUEST['method']=='SPA')
> echo "<span class='style3'>".htmlentities("Mode de Navigation :
> ")."</span><span
> class='style3'>".htmlentities("Piéton")."</span></span><br>";
> if ($_REQUEST['method']=='SPS')
> echo "<span class='style3'>Mode de Navigation :</span><span
> class='style3'>Voiture</span><br>";
> echo "<span class='style3'>".htmlentities("Type d'itinéraire :
> ")."</span><span class='style3'>Le plus court</span><br>";
> } else {
> ")."</span><span class='style3'>Le plus Rapide</span><br>";
>  echo "<span class='style3'>Longueur du Trajet : </span><span
> class='style3'>";
> echo ConvertDistance(round(($pathlength),0))."</span><br>";
> echo "<span class='style3'>Temps total du Trajet : </span><span
> class='style3'>";
> echo ConvertTemps($temps_trajet)."</span></br>";
> echo "</div>";
> echo "</br>";
> echo "</br>";
> echo "</br>";
> echo "</br>";
>  //echo $xml;
> //  echo "<p>_______________________________________________<p>";
> //  echo $counter."<p>";
> //   echo "_______________________________________________<p>";
> //for($i=1; $i<=$counter ; $i++) {
> //echo "&&startPoint[".$i."] = array(".$x1[$i].",".$y1[$i].");<p>";
> //echo "&&endPoint[".$i."] = array(".$x2[$i].",".$y2[$i].");<p>";
> //echo "&&rue[".$i."] = |".$rue[$i]."|;<p>";
>  //recherche du premier tronçon de la route
>  if ($ii[$i]==$startEdge['gid']) {
> // echo "<script>alert(".$startEdge['gid'].");</script>";
>  //stockage temporaire de la ligne n°1
>  $tt=$rue[1];
>  $st=$startPoint[1];
>  $se=$endPoint[1];
>  $ll= $length[1];
>  $tm= $temps[1];
>  $xxx1=$x1[1];
>  $xxx2=$x2[1];
>  $yyy1=$y1[1];
>  $yyy2=$y2[1];
>  $type_route=$type[1];
>  //Attribution de la ligne n° 1 au premier tronçon de la route
>  $rue[1]=$rue[$i];
>  $startPoint[1]=$startPoint[$i];
>  $endPoint[1]=$endPoint[$i];
>  $length[1]=$length[$i];
>  $temps[1]=$temps[$i];
>  $x1[1]=$x1[$i];
>  $x2[1]=$x2[$i];
>  $y1[1]=$y1[$i];
>  $y2[1]=$y2[$i];
>  $type[1]=$type[$i];
>  //attribution du tronçon n° i de l'ex début de route par l'exe premier
> enregistrement
>  $rue[$i]=$tt;
>  $startPoint[$i]=$st;
>  $endPoint[$i]=$se;
>  $length[$i]=$ll;
>  $temps[$i]=$tm;
>  $x1[$i]=$xxx1;
>  $x2[$i]=$xxx2;
>  $y1[$i]=$yyy1;
>  $y2[$i]=$yyy2;
>  $type[$i]=$type_route;
>  $i=1;
>  $j=1;
>  for($j=$i+1; $j<=$counter ; $j++)
>  if ($startPoint[$j]==$endPoint[$i])
> $T0=$startPoint[$j];
> $T1=$startPoint[$i+1];
> $T2=$endPoint[$j];
> $T3=$endPoint[$i+1];
> $T4=$rue[$j];
> $T5=$rue[$i+1];
> $T6=$length[$j];
> $T7=$length[$i+1];
> $T8=$temps[$j];
> $T9=$temps[$i+1];
> $T10=$x1[$j];
> $T11=$x1[$i+1];
> $T12=$y1[$j];
> $T13=$y1[$i+1];
> $T14=$x2[$j];
> $T15=$x2[$i+1];
> $T16=$y2[$j];
> $T17=$y2[$i+1];
> $T18=$type[$j];
> $T19=$type[$i+1];
> $startPoint[$j]=$T1;
> $startPoint[$i+1]=$T0;
> $endPoint[$j]=$T3;
> $endPoint[$i+1]=$T2;
> $rue[$j]=$T5;
> $rue[$i+1]=$T4;
> $length[$j]=$T7;
> $length[$i+1]=$T6;
> $temps[$j]=$T9;
> $temps[$i+1]=$T8;
> $x1[$j]=$T11;
> $x1[$i+1]=$T10;
> $y1[$j]=$T13;
> $y1[$i+1]=$T12;
> $x2[$j]=$T15;
> $x2[$i+1]=$T14;
> $y2[$j]=$T17;
> $y2[$i+1]=$T16;
> $type[$j]=$T19;
> $type[$i+1]=$T18;
>  for($i=0; $i<=$counter ; $i++)
>  //assemblage des tronçons par nom des rues
> $comt_temp +=1;
> $temps_troncon += $temps[$i];
> $temps_cumule +=$temps[$i];
> $length_troncon +=$length[$i];
> $length_cumule +=$length[$i];
>  if ($rue[$i+1]!=$rue[$i])
> $etape +=1;
> if ($etape % 2 != 0) {
> //echo "<tr bgcolor='#B8E1F5'>";
> } else {
> //echo "<tr>";
> //echo "<td><span class='style2'>".$etape."</span></td>";
>  //echo "<td><span class='style1'>";
> if ($i==1) {
> //echo "<IMG width=32 height=32 SRC=img/drapeau/11.gif> Prendre ";
>  } elseif ($i==$counter) {
> //echo "<IMG width=32 height=32 SRC=img/drapeau/12.gif> Arrivé à ";
> } else {
>  //echo direction($x1[$i-1],$y1[$i-1],$x1[$i],$y1[$i],$x1[$i+1],$y1[$i+1],
> $x1[$i+2],$y1[$i+2], $type[$i+1]);
> $direction[$i]=direction($x1[$i-1],$y1[$i-1],$x1[$i],$y1[$i],$x1[$i+1],$y1[$i+1],
> //echo $rue[$i]."</span></td>";
> $NomRue[$i]=$rue[$i];
> //echo "<td><span class='style2'>";
> //echo ConvertDistance($length_troncon)."</span></td>";
> $DistanceTroncon[$i]=ConvertDistance($length_troncon);
> //echo ConvertDistance($length_cumule)."</span></td>";
> $DistanceCumul[$i]=ConvertDistance($length_cumule);
> //echo ConvertTemps($temps_troncon)."</span></td>";
> $TempsTroncon[$i]=ConvertTemps($temps_troncon);
> //echo ConvertTemps($temps_cumule)."</span></td>";
> $TempsCumul[$i]=ConvertTemps($temps_cumule);
> //echo "</tr>";
> //initialiser le compteur
> $comt_temp =0;
> $temps_troncon=0;
> $length_troncon=0;
>   //echo "</table>";
> echo "<div style='background-color:#f0f0f0; color:#00519e; padding:0 10px;
> margin-bottom:5px;'><div style='float:left; width:275px;'><img
> src='img/drapeau/14.png'>".htmlentities("Départ")." :
> ".$txtStart."</div></div><br>";
> 10px; margin-bottom:5px;'><div style='float:left;
> width:275px;'>".$direction[0]."</div>";
>   echo $DistanceTroncon[1]."</div>";
> 10px; margin-bottom:5px;'><div style='float:left; width:275px;'> de
> </div></div>";
> width:275px;'>".$NomRue[1]."</div></div>";
> width:275px;'>".htmlentities("  ")."</div></div>";
>   echo "<p>";
>   for($i=1; $i<=$counter-2 ; $i++)
> width:275px;'>".$direction[$i]."</div></div>";
> echo "  ";
> width:275px;'>".$NomRue[$i+1]."</div>";
> echo $DistanceTroncon[$i]."</div>";
> //echo "coucou";
> //echo "<p>";
> width:275px;'>".$direction[$counter-1]."</div></div>";
> width:275px;'>".$direction[$i]."</div></div>";htmlentities(" et vous
> arrivez
> à ")."</div></div>";
> width:275px;'>".$NomRue[$counter]."</div>";
>   echo $DistanceTroncon[$counter-1]."</div></div>";
> 10px; margin-bottom:5px;'><div style='float:left; width:275px;'><img
> src='img/drapeau/15.png'>".htmlentities("Arrivé")." :
> ".$txtEnd."</div></div><br>";
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110201/58011936/attachment.html
> Pgrouting-users at lists.osgeo.org
> End of Pgrouting-users Digest, Vol 29, Issue 2
Cléber D. Arruda
Kämnärsvägen 33C
226 46
Lund - Sweden
Phone +46737762526
E-mail: cleverdo at gmail.com
Peace and Love Always.
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110202/1636ccaf/attachment-0001.html
More information about the Pgrouting-users mailing list
