[pgrouting-users] TSP and how to contribute
Stephen Woodbridge woodbri at swoodbridge.com
Sat Jan 15 10:23:21 EST 2011
On 1/15/2011 12:20 AM, Daniel Kastl wrote:
>     This is why we need a function that returns the solved dijkstra tree
>     like:
>     node_id, cost, parent_node_id
>     for all nodes in the solution. You can then retrieve the
>     edge(parent_node_id, node_id). cost is the accumulated cost to get
>     to node_id from the start node. parent_node_id should be NULL or -1
>     to indicate the node_id is the start node.
> Good point. I agree.
> Since the returned "edge" column is more or less useless, don't you
> think it would fit in the current schema?
> http://www.pgrouting.org/docs/1.x/dd.html
> Just replace edge_id column with parent_node_id and cost
> as accumulated cost.
> That said, I unfortunately have no knowledge in C/C++. If someone
> thinks, this isn't difficult, please go ahead!
>     This allows anyone to do a Dijkstra solution and get back the full
>     results of that solution. One of the goal of pgRouting is to better
>     support arbitrary graph analysis within the database and this would
>     greatly help in this area. We need the high level wrapper functions
>     like we already have because they are convenient, but we currently
>     hide access to the underlying graph solutions so people can not use
>     it to do things like Emre is trying to do.
> Also agree.
> Do you think this applies also to shortest path functions or are they
> "open" enough?
The shortest path if you are talking about a simple dijkstra solution,
we have the same issue as driving distance. Both use a Dijkstra solution
the only difference is when the solution is terminated. Driving distance
it terminated when all node on the frontier are greater then or equal to
the cut off distance. For the shortest path, it terminates when the
graph is solved or when the target node is reached depending on how it
is coded. Then in both cases, the resulting tree is post-processed to
extract additional information, ie: the start to end route or the
driving distance polygons.
So what are the use cases for this:
1. Say you want to do a TSP (not using our existing code). If You had 10
points, then you could run 10 Dijkstra solutions, one for each point and
from each solution extract the route and cost to the other nine points.
This is like a selective all paths solution, I call it some paths
solution. This is very efficient and lets you collect all the inputs to
solve the TSP and after you have solved it you already have all the
routes computed and cached. Also, if you can reuse the graph for each of
the ten solutions, rather than rebuild the same graph ten times, it is
significantly faster.
2. We already discussed drive time analysis
3. We talked about the need to reverse the graph for destination drive
time analysis
4. The obvious on of shortest path between start and end.
I'm sure there are other analysis that need this as it is one of the
more basic graph analysis, but my brain is not fully awake yet.
So one issue I see in refactoring this, is for example building a graph
and reusing that graph probably all has to be done inside a single C/C++
call or you have to build a mechanism to save the graph to a blob or
somewhere and then reload it when you later want to use it. So this
might all need to be wrapped into a single call.
> Probably we should add some tickets.
Yes this would be a good idea, if nothing else to capture the ideas and
discussion. Or I think you already started some RFCs. This would be a
better way to document and discuss these issues. tickets should be used
to document actual work or bugs.
-Steve
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de <mailto:daniel.kastl at georepublic.de>
> Web: http://georepublic.de <http://georepublic.de/>
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
