[pgrouting-users] Import large OSM data for routing
Daniel Kastl daniel at georepublic.de
Wed Jan 19 12:53:30 EST 2011
Hi Lorenzo,
Can you try to also output "id" with "ORDER BY id"
SELECT id, gid, AsText(the_geom) from
astar_sp_delta('osm_topo',723,6610,0.1) ORDER BY id;
This "id" should be in the right order ... but I'm not 100% sure this was
added to all wrapper functions. Can you try once?
Daniel
2011/1/20 lorenzo amato <lorenzo.amato at geosdi.org>
> Hi List
> before import the whole italy.osm with osm2po I'm doing some test with a
> smaller portion of data.
> I notice a strange behaviour:
> If I use the core A* function I get a correct resultset (i.e.
> multininestrings are consecutive)
> If I use the wrapper function astar_sp_delta I get a wrong resultset (i.e.
> multilinestring ordered by gid and not consecutive)
> This not affects the rendering of the whole route, but makes impossible
> other operations like the driving direction calculation, tha needs to
> compare two consecutive rows of the result at time.
> *Any idea on why this appen?*
> This is an example to understand the different results:
> osm2po=# SELECT * from shortest_path_astar('select gid as id, source,
> target, length as cost, x1,y1,x2,y2 from osm_topo',723,6610,false,false);
> LOG:  statement: SELECT * from shortest_path_astar('select gid as id,
> source, target, length as cost, x1,y1,x2,y2 from
>  vertex_id | edge_id |   cost
>        723 |     683 | 0.006361
>        722 |     682 | 0.000656
>        721 |     696 |  9.3e-05
>        732 |     697 | 0.000377
>        731 |     693 | 0.000575
>        726 |     685 |  0.00025
>        727 |     686 | 0.000927
>        724 |    7820 | 0.000661
>       2333 |    7819 | 0.003565
>        976 |    7818 | 0.000274
>       6610 |      -1 |        0
> (11 rows)
> osm2po=# SELECT gid, AsText(the_geom) from
> astar_sp_delta('osm_topo',723,6610,0.1);
> LOG:  statement: SELECT gid, AsText(the_geom) from
>  gid  |                                                            astext
>   682 | MULTILINESTRING((14.9979217 41.9939472,14.997744 41.9942112))
>   683 | MULTILINESTRING((14.997744 41.9942112,14.9974089
> 41.9947092,14.9962375 41.9963223,14.9958494 41.9966941))
>   685 | MULTILINESTRING((14.9982187 41.9934783,14.9982846 41.9933772))
>   686 | MULTILINESTRING((14.9982846 41.9933772,14.9983547
> 41.9932913,14.9983794 41.9932546,14.9984662 41.9931742,14.99858 41.993024))
>   693 | MULTILINESTRING((14.9980506 41.9937596,14.9981486
> 41.9935518,14.9982187 41.9934783))
>   696 | MULTILINESTRING((14.9979217 41.9939472,14.9979489 41.9939108))
>   697 | MULTILINESTRING((14.9979489 41.9939108,14.9980265
> 41.9938069,14.9980506 41.9937596))
>  7818 | MULTILINESTRING((14.9998359 41.9912293,14.9997606 41.991339))
>  7819 | MULTILINESTRING((14.9997606 41.991339,14.9991878
> 41.9921736,14.9987675 41.9927617))
>  7820 | MULTILINESTRING((14.9987675 41.9927617,14.99858 41.993024))
> (10 rows)
> 2011/1/19 lorenzo amato <lorenzo.amato at geosdi.org>
> Richard
>> Thanks very much for your suggestion.
>> I'mk going to test osm2po for creating pgRouting compatible tables and it
>> seems great.
>> I will post to the list some more considerations at the end of my tests.
>> Lorenzo
>> 2011/1/18 Richard Marsden <winwaed at gmail.com>
>> Try the osm2po program instead. This can handle large files, and recently
>>> I was able to use it to import planet.osm. Osm2po create an SQL script which
>>> you then execute. Planet.osm took a few days to import - Italy should be a
>>> lot quicker!
>>> Search the archives of this list server - I had a couple of queries which
>>> were quickly answered. They may help you, especially if you are new to
>>> PostGis and pgRouting (as I am).
>>> Richard.
>>> On Jan 18, 2011, at 10:42 AM, lorenzo amato <lorenzo.amato at geosdi.org>
>>> wrote:
>>> Hi list
>>> I'm trying to import a large osm file (italy.osm from cloudmade) into
>>> postgis using the osm2pgrouting tool without success.
>>> I read somewhere in the list (or in the wikies) that osm2pgrouting uses a
>>> large amount of memory.
>>> So i tried to lounch osm2pgrouting on a workstation with 32G RAM ...
>>> without success.
>>> I also found this thread:
>>> <http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/discussion/topic/297.html>
>>> and this wiki page
>>> <http://download.osgeo.org/pgrouting/forum/pgrouting.postlbs.org/wiki/osm2pgroutingPatchToAppendFile.html>
>>> but some errors occurred whan I tryed to apply the patch.
>>> Any help?
>>> Or any other way to import large OSM data for routing?
>>> Lorenzo Amato
>>> <lorenzo.amato at geosdi.org>lorenzo.amato at geosdi.org
>>> <lorenzotlc at gmail.com>lorenzotlc at gmail.com
>>>  <lorenzo.amato at nsdi.it>lorenzo.amato at nsdi.it
>>> Consiglio Nazionale delle Ricerche
>>> Istituto di Metodologie per l'Analisi Ambientale - geoSDI
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Lorenzo Amato
> Lorenzo Amato
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110120/c3011918/attachment-0001.html
More information about the Pgrouting-users mailing list
