[pgrouting-users] Nasty crash from pgRouting
Stephen Woodbridge woodbri at swoodbridge.com
Mon Jan 31 14:11:52 EST 2011
On 1/31/2011 10:36 AM, Richard Marsden wrote:
> Anton & Daniel,
> Thanks.
> I saw some references to problems with negative reverse_cost. I've
> checked the data and I don't have any negative cost or reverse_cost
> values. Plenty of zeroes though.
Ahhh, I'm guessing the zero cost is just as bad as negative costs, but I
might be wrong on this. I would try setting all the zero costs to some
really small positive cost and see if that helps.
Or if you really have zero length segments, then why not reduce the size
of your graph by removing all of them.
You should also check the the source and target ids are not the same. as
this is problematic also. If you have a cul d'sac there the start and
end are the same but it does a loop, then you should split the loop into
two segments.
-Steve
> Highest node value is 49,608,314 - so I don't think it is the integer
> overflow problem I'm seeing discussed.
> I also tried Iran (northern hemisphere, not too big, imperfect road data
> in osm) and it also crashes. The common thread seems to be that
> countries where I can't match all (geonames-derived) cities with osm
> nodes, crash using valid nodes. This isn't a simple "route cannot be
> found" as my UK Belfast example demonstrates (no routes possible from
> Belfast to the England - no crash occurs)
> One problem is that all I'm getting is a big crash - nothing indicates
> what the problem actually is.
> My laptop can boot into Ubuntu but the partition will be too small and
> the cpu too slow.
> The machine I'm using is my main batch processing /testing machine. It
> currently doesn't have space for a Unix/Linux partition, but has enough
> spare disk bays.  I was already thinking of buying a large (1TB+) hard
> disk for this project. Although I've managed to squeak by with what I
> have, and PostGres's requirements aren't too big, manipulating
> planet.osm files does take some disk space!
> Perhaps this is the way forward then: New disk and try building an
> Ubuntu partition with postgres/etc. Assuming I don't have to rerun
> osm2po, it should take me a couple of days to rebuild everything.
> Most of my 'stack' should run fine on Ubuntu - Postgres, PostGis,
> Python. Windows is being used partly for historical reasons (earlier
> versions of my Python scripts used Windows for a good reason which no
> longer applies), but also I'm using Excel for my output. Perhaps there's
> a cross-platform Python library I can use. If not, I could create CSV
> files and "tie them together" with a Windows-based script (they're
> simple data sheets but I am relying on some formatting to make the data
> easier to use).
> re. building: I actually do most of my dev in Windows but using Visual
> Studio. I've seen the pgRouting Windows build instructions and they
> don't look very Windows friendly! Believe it or not I would be happier
> doing such builds in a Unix/Linux type of environment...     (I've built
> my own UMN Mapserver with FreeBSD in the past).
> The project can't go forward if these crashes continue. So a little bit
> of a gamble that a new disk (or two if I decide on RAID) and Ubuntu will
> fix it...
> Richard
> On Sun, Jan 30, 2011 at 9:51 PM, Daniel Kastl <daniel at georepublic.de
> <mailto:daniel at georepublic.de>> wrote:
>     Hi Richard,
>     You could try OSGeo Live DVD with already installed pgRouting in
>     Virtualbox for example just to see if a newer version of would solve
>     your issue: http://live.osgeo.org/
>     <http://live.osgeo.org/>As Anton mentioned, there seem to be not
>     many developers out there, who are willing (or have the knowledge)
>     to contribute Windows binaries.
>     My feeling is that most pgRouting installations are running on Linux
>     servers, while most users, who just want to try out pgRouting,
>     prefer to do this on Windows.
>     Daniel
>     2011/1/31 Anton Patrushev <anton.patrushev at georepublic.de
>     <mailto:anton.patrushev at georepublic.de>>
>         Hi Richard,
>         Unfortunately Win binaries are quite old because nobody is
>         willing to
>         make new ones.
>         There can be few different reasons why it crushes (data problem for
>         example). Do you have any Linux box around to test your data with
>         newer version of pgRouting?
>         Anton.
>         _______________________________________________
> Pgrouting-users mailing list
> Pgrouting-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
More information about the Pgrouting-users mailing list
