[pgrouting-users] Nasty crash from pgRouting
    Richard Marsden
    winwaed at gmail.com
    Mon Jan 31 18:30:28 EST 2011
Steve,
I'm a little confused, well not confused, unclear perhaps. :-)
I'm using the dijkstra_sp_delta() function. This doesn't explicitly say
whether it uses directions and reverse costs. My results so far suggests it
ignores directed graphs completely.
If it is using cost and reverse_cost, presumably I could just set these to
the length values.
So I tried this, but I'm still getting the crash.
I do have some very small lengths - the smallest is being reported as
1.0E-7.
The data was imported by osm2po from planet.osm.
I'm assuming this (or these) tiny distances are due to what are essentially
duplicated nodes which are sufficiently far apart that osm2po does not
recognize them as duplicates.
I've just done a search for links with the same source and target node
identifiers - no matches.
(for my application, I could actually delete the cul-de-sac loops that you
describe)
The new hard disk is on order for an attempt to build everything in Ubuntu.
Richard
On Mon, Jan 31, 2011 at 1:11 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 1/31/2011 10:36 AM, Richard Marsden wrote:
>> Anton & Daniel,
>> Thanks.
>> I saw some references to problems with negative reverse_cost. I've
>> checked the data and I don't have any negative cost or reverse_cost
>> values. Plenty of zeroes though.
> Ahhh, I'm guessing the zero cost is just as bad as negative costs, but I
> might be wrong on this. I would try setting all the zero costs to some
> really small positive cost and see if that helps.
> Or if you really have zero length segments, then why not reduce the size of
> your graph by removing all of them.
> You should also check the the source and target ids are not the same. as
> this is problematic also. If you have a cul d'sac there the start and end
> are the same but it does a loop, then you should split the loop into two
> segments.
> -Steve
>  Highest node value is 49,608,314 - so I don't think it is the integer
>> overflow problem I'm seeing discussed.
>> I also tried Iran (northern hemisphere, not too big, imperfect road data
>> in osm) and it also crashes. The common thread seems to be that
>> countries where I can't match all (geonames-derived) cities with osm
>> nodes, crash using valid nodes. This isn't a simple "route cannot be
>> found" as my UK Belfast example demonstrates (no routes possible from
>> Belfast to the England - no crash occurs)
>> One problem is that all I'm getting is a big crash - nothing indicates
>> what the problem actually is.
>> My laptop can boot into Ubuntu but the partition will be too small and
>> the cpu too slow.
>> The machine I'm using is my main batch processing /testing machine. It
>> currently doesn't have space for a Unix/Linux partition, but has enough
>> spare disk bays.  I was already thinking of buying a large (1TB+) hard
>> disk for this project. Although I've managed to squeak by with what I
>> have, and PostGres's requirements aren't too big, manipulating
>> planet.osm files does take some disk space!
>> Perhaps this is the way forward then: New disk and try building an
>> Ubuntu partition with postgres/etc. Assuming I don't have to rerun
>> osm2po, it should take me a couple of days to rebuild everything.
>> Most of my 'stack' should run fine on Ubuntu - Postgres, PostGis,
>> Python. Windows is being used partly for historical reasons (earlier
>> versions of my Python scripts used Windows for a good reason which no
>> longer applies), but also I'm using Excel for my output. Perhaps there's
>> a cross-platform Python library I can use. If not, I could create CSV
>> files and "tie them together" with a Windows-based script (they're
>> simple data sheets but I am relying on some formatting to make the data
>> easier to use).
>> re. building: I actually do most of my dev in Windows but using Visual
>> Studio. I've seen the pgRouting Windows build instructions and they
>> don't look very Windows friendly! Believe it or not I would be happier
>> doing such builds in a Unix/Linux type of environment...     (I've built
>> my own UMN Mapserver with FreeBSD in the past).
>> The project can't go forward if these crashes continue. So a little bit
>> of a gamble that a new disk (or two if I decide on RAID) and Ubuntu will
>> fix it...
>> Richard
>> On Sun, Jan 30, 2011 at 9:51 PM, Daniel Kastl <daniel at georepublic.de
>> <mailto:daniel at georepublic.de>> wrote:
>>    Hi Richard,
>>    You could try OSGeo Live DVD with already installed pgRouting in
>>    Virtualbox for example just to see if a newer version of would solve
>>    your issue: http://live.osgeo.org/
>>    <http://live.osgeo.org/>As Anton mentioned, there seem to be not
>>    many developers out there, who are willing (or have the knowledge)
>>    to contribute Windows binaries.
>>    My feeling is that most pgRouting installations are running on Linux
>>    servers, while most users, who just want to try out pgRouting,
>>    prefer to do this on Windows.
>>    Daniel
>>    2011/1/31 Anton Patrushev <anton.patrushev at georepublic.de
>>    <mailto:anton.patrushev at georepublic.de>>
>>        Hi Richard,
>>        Unfortunately Win binaries are quite old because nobody is
>>        willing to
>>        make new ones.
>>        There can be few different reasons why it crushes (data problem for
>>        example). Do you have any Linux box around to test your data with
>>        newer version of pgRouting?
>>        Anton.
>>        _______________________________________________
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/pgrouting-users
URL: http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20110131/d6821c7a/attachment.html
More information about the Pgrouting-users
