[pgrouting-users] How many people use the wrapper functions?
Stephen Woodbridge woodbri at swoodbridge.com
Sat May 11 19:05:26 PDT 2013
Hi Pavel,
Thanks you for your feedback. This is exactly why we are thinking about
thinning down the list of function. The history on this was that these
were originally written to explain how to use the core functions
efficiently but the problem is that there are only examples and they
really don't fit well to most peoples use cases. I believe (maybe
erroneously) that most users have taken one  or two of the wrappers and
modified them for their own use cases.
One of the things that we will also be working on is a new tutorial
based on the new algorithms and we hope to address some of these
educational issues in that also.
Thanks again for your feedback.
I look forward to hearing from others on either side of these issues.
Thanks,
   -Steve
On 5/11/2013 4:54 PM, Pavel Iacovlev wrote:
> I don't, probably for the same reasons, if you need to use/swap
> multiple algorithms using wrapper functions can get really tricky.
> With the amount of helper functions current available (astar example)
> astar_sp
> astar_sp_bbox
> astar_sp_bbox_directed
> astar_sp_delta
> astar_sp_delta_cc
> astar_sp_delta_cc_directed
> astar_sp_delta_directed
> astar_sp_directed
> it's just easier to lean the API, and there are great examples in the
> workshop to do so.
> On Sat, May 11, 2013 at 11:20 PM, Stephen Woodbridge
> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>     Hi all,
>     Daniel and I have been wondering if people use the wrapper function
>     versus the core functions directly? Or if you have written your own
>     wrapper functions? etc.
>     The core functions are the low level function that directly call the
>     internal library functions.
>     The wrapper functions are all the additional plpgsql convenience
>     functions that generate more complex SQL queries and then call the
>     core functions.
>     I know that I never use the wrapper functions because I found them
>     to messy and inconsistent and have hard coded values in them, etc.
>     So I wrote my own high level wrapper functions that made it easy for
>     me to work with the core functions.
>     So I thought it would be wise to ask our users what they use? and
>     how they use pgRouting, so we do not may a decision like "Throw out
>     the wrapper functions" without some input from the user community.
>     PLEASE TAKE ACTION and let us know!
>     Thanks,
>        -Steve
>     _________________________________________________
>     Pgrouting-users mailing list
>     Pgrouting-users at lists.osgeo.__org
>     <mailto:Pgrouting-users at lists.osgeo.org>
>     http://lists.osgeo.org/__mailman/listinfo/pgrouting-__users
>     <http://lists.osgeo.org/mailman/listinfo/pgrouting-users>
More information about the Pgrouting-users mailing list
