[pgrouting-users] Converting a shape file to a network
Dave Potts mrdapotts at gmail.com
Sat May 19 04:45:23 PDT 2018
I tried this and got an error message to the effect missing column
med_proj=# \d tmp;
                                     Table "public.tmp"
  Column  |          Type           | Collation | Nullable |
 Default
 id       | integer                 |           | not null |
nextval('tmp_id_seq'::regclass)
 the_geom | geometry(Geometry,3857) |           |          |
med_proj=# \d tmp_noded;
                                     Table "public.tmp_noded"
Default
nextval('tmp_noded_id_seq'::regclass)
 old_id   | bigint                  |           |          |
 sub_id   | bigint                  |           |          |
 source   | bigint                  |           |          |
 target   | bigint                  |           |          |
Invoking this, should put the results in tmp_noded, which according to the
above and the manual at
https://docs.pgrouting.org/2.6/en/pgr_nodeNetwork.html has all the right
column
Doing this
med_proj=# select pgr_createTopology('tmp',1);
Given an error,  I don't  think there is anything wrong with the functions,
it most be my table layout, but according to the documents,everything is
correct.
NOTICE:  PROCESSING:
NOTICE:  pgr_createTopology('tmp', 1, 'the_geom', 'id', 'source', 'target',
rows_where := 'true', clean := f)
NOTICE:  Performing checks, please wait .....
NOTICE:  ----> PGR ERROR in pgr_createTopology: Column source not found
HINT:    ----> Check your column name
NOTICE:  Unexpected error raise_exception
 pgr_createtopology
 FAIL
any ideas what I am doing wrong ?
Dave.
On 17 May 2018 at 21:35, Vicky Vergara <vicky at georepublic.de> wrote:
> Hi Dave,
> Have you tried:
> Its has some issues, but does a reasonable work for pgRouting purposes.
> Fixing the geometry would be using postGIS
> On Thu, May 17, 2018 at 2:47 PM, Dave Potts <mrdapotts at gmail.com> wrote:
>> Hi,
>> I am trying to convert a shapefile of linestrings into a suitable form
>> for pgroute.  The type of issue that I am getting is that from a casual
>> look its looks fine, but if you drill down in to the map, you find there
>> are some line segments should connect, but they don't due to the way that
>> the data was entered.
>> Q. Has anybody attempt this type of thing before and what if any
>> solutions did they find ?
>> Dave.
>> Pgrouting-users mailing list
>> Pgrouting-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
> Georepublic UG (haftungsbeschränkt)
> Salzmannstraße 44,
> 81739 München, Germany
> Vicky Vergara
> Operations Research
> eMail: vicky at georepublic.de
> Web: https://georepublic.info
> Tel: +49 (089) 4161 7698-1
> Fax: +49 (089) 4161 7698-9
> Commercial register: Amtsgericht München, HRB 181428
> CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180519/378cbe25/attachment.html>
More information about the Pgrouting-users mailing list
