[pgrouting-users] Converting a shape file to a network
Vicky Vergara vicky at georepublic.de
Sat May 19 07:47:44 PDT 2018
Dave:
your table "tmp" does only has id and the_geom columns
On Sat, May 19, 2018 at 6:45 AM, Dave Potts <mrdapotts at gmail.com> wrote:
> I tried this and got an error message to the effect missing column
> med_proj=# \d tmp;
>                                      Table "public.tmp"
>   Column  |          Type           | Collation | Nullable |
>  Default
>  id       | integer                 |           | not null |
> nextval('tmp_id_seq'::regclass)
>  the_geom | geometry(Geometry,3857) |           |          |
> med_proj=# \d tmp_noded;
>                                      Table "public.tmp_noded"
>   Default
> nextval('tmp_noded_id_seq'::regclass)
>  old_id   | bigint                  |           |          |
>  sub_id   | bigint                  |           |          |
>  source   | bigint                  |           |          |
>  target   | bigint                  |           |          |
> Invoking this, should put the results in tmp_noded, which according to the
> above and the manual at https://docs.pgrouting.org/
> 2.6/en/pgr_nodeNetwork.html has all the right column
> Doing this
> med_proj=# select pgr_createTopology('tmp',1);
> Given an error,  I don't  think there is anything wrong with the
> functions, it most be my table layout, but according to the
> documents,everything is correct.
> NOTICE:  PROCESSING:
> NOTICE:  pgr_createTopology('tmp', 1, 'the_geom', 'id', 'source',
> 'target', rows_where := 'true', clean := f)
> NOTICE:  Performing checks, please wait .....
> NOTICE:  ----> PGR ERROR in pgr_createTopology: Column source not found
> HINT:    ----> Check your column name
> NOTICE:  Unexpected error raise_exception
>  pgr_createtopology
>  FAIL
> any ideas what I am doing wrong ?
> Dave.
> On 17 May 2018 at 21:35, Vicky Vergara <vicky at georepublic.de> wrote:
>> Hi Dave,
>> Have you tried:
>> https://docs.pgrouting.org/2.6/en/pgr_nodeNetwork.html
>> Its has some issues, but does a reasonable work for pgRouting purposes.
>> Fixing the geometry would be using postGIS
>> On Thu, May 17, 2018 at 2:47 PM, Dave Potts <mrdapotts at gmail.com> wrote:
>>> Hi,
>>> I am trying to convert a shapefile of linestrings into a suitable form
>>> for pgroute.  The type of issue that I am getting is that from a casual
>>> look its looks fine, but if you drill down in to the map, you find there
>>> are some line segments should connect, but they don't due to the way that
>>> the data was entered.
>>> Q. Has anybody attempt this type of thing before and what if any
>>> solutions did they find ?
>>> Dave.
>>> Pgrouting-users mailing list
>>> Pgrouting-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-users
>> Georepublic UG (haftungsbeschränkt)
>> Salzmannstraße 44,
>> 81739 München, Germany
>> Vicky Vergara
>> Operations Research
>> eMail: vicky at georepublic.de
>> Web: https://georepublic.info
>> Tel: +49 (089) 4161 7698-1
>> Fax: +49 (089) 4161 7698-9
>> Commercial register: Amtsgericht München, HRB 181428
>> CEO: Daniel Kastl
Salzmannstraße 44,
Vicky Vergara
Operations Research
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-users/attachments/20180519/576e6740/attachment-0001.html>
More information about the Pgrouting-users mailing list
