[postgis-devel] Re: getrelid && list_nth
'strk' strk at keybit.net
Wed Jun 9 01:56:49 PDT 2004
On Wed, Jun 09, 2004 at 09:39:26AM +0100, Mark Cave-Ayland wrote:
> Hi strk,
> > -----Original Message-----
> > From: strk [mailto:strk at keybit.net]
> > Sent: 08 June 2004 18:19
> > To: Mark Cave-Ayland
> > Cc: postgis-devel at postgis.refractions.net
> > Subject: getrelid && list_nth
> > Hello Mark,
> > I was writing this to pgsql-hackers, but I've solved it
> > so I turned it into a report.
> > Working on postgis selectivity function for type 'geometry'
> > I've incurred in the following problem:
> > The getrelid() macro defined in parser/parsetree.h invokes
> > the rt_fetch() macro therein defined, which in turn invokes list_nth.
> > Now list_nth() is not a macro, and postgis
> > is not linked to postgresql dynamic library, so
> > it fails to load.
> > This worked until some months ago (PG was already
> > versioned as 75dev).
> FYI the List API has recently changed in PostgreSQL 7.5 which is
> probably why this has broken - please see the following links:
> http://archives.postgresql.org/pgsql-patches/2004-05/msg00344.php
> http://archives.postgresql.org/pgsql-patches/2004-05/msg00376.php
> and the thread here:
> http://archives.postgresql.org/pgsql-patches/2004-05/msg00500.php
> > To fix this I've copied list_nth and list_nth_cell into
> > postgis_estimate.c removing superflous ( I hope ) checks on
> > boundaries.
> Yuck. I don't think we should be duplicating the PostgreSQL list API
> just because the API has changed between versions. Any chance you could
> look at the posted patch and correct CVS so that this is not needed?
Do you mean the PGSQL List API change patch ?
> > Now estimation selectivity is back up and runnign for PG75
> > Still... any stable utility interface would be appreciated.
> BTW did you find that building large GiST indices crashes PostgreSQL?
Nope. I haven't been playing with PG75 for a while.
> Since the GiST API has changed you will probably need to apply my "super
> patch" in order to get things working correctly as the problem wasn't
> just a Win32 issue (see
> http://postgis.refractions.net/pipermail/postgis-users/2004-May/004918.h
> tml)
> Would any developers object if the "super patch" for 7.5 were to be
> applied to CVS? If no-one objects I'd like to apply it real soon....
I'll take a look at it.
--strk;
> Cheers,
> Mark.
> Mark Cave-Ayland
> Webbased Ltd.
> Tamar Science Park
> Derriford
> Plymouth
> PL6 8BX
> England
> Tel: +44 (0)1752 764445
> Fax: +44 (0)1752 764446
> This email and any attachments are confidential to the intended
> recipient and may also be privileged. If you are not the intended
> recipient please delete it from your system and notify the sender. You
> should not copy it or use it for any purpose nor disclose or distribute
> its contents to any other person.
