[postgis-devel] autoconf paths
alex bodnaru alexbodn at 012.net.il
Fri Apr 15 10:54:52 PDT 2005
strk,
this paths problem is quite easily solvable: run pg_config --help for
the various options
alex
On Fri, 2005-04-15 at 16:53 +0200, strk at refractions.net wrote:
> I started working on pgsql source code requirement drop.
> One of the problems (apart from linking flags and other
> OS/Compiler/Arch-specific things) is installation paths.
> Currently PostGIS gets installed under PGSQL installation
> tree. Should we instead create a postgis-specific install
> layout ? Something like:
> 	PREFIX/doc <-- the postgis manual, README and similar
> 	PREFIX/man <-- loader/dumper manual pages
> 	PREFIX/bin <-- loader/dumper/utils
> 	PREFIX/share <-- sql scripts, regression tests
> As often happen, if PREFIX is not specified might be worth to modify
> some paths to contain an explicit 'postgis' suffix, like in:
> 	PREFIX/doc/postgis/
> 	PREFIX/share/postgis/
> Note that this is a problem because pg_config won't tell us
> where is postgresql installed.
> Thoughts ?
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
