RES: [postgis-devel] Autoprobing java source files
alex bodnaru alexbodn at 012.net.il
Wed Apr 20 18:29:51 PDT 2005
hi markus,
don't forget about keeping the linux version free !
best regards
alex
On Wed, 2005-04-20 at 14:37 +0200, Markus Schaber wrote:
> Hi, Gustavo,
> Gustavo Henrique Sberze Ribas schrieb:
> >  Or, if I may abuse your good will, you could deliver an Ant
> > (java version of "make") build.xml. :)
> Originally, my jdbc2 code had partially replaced the old jdbc2 Makefile
> with an ant script.
> However, we wanted to avoid introducing an additional build dependency.
> And maintaining both the build.xml and Makefile in parallel would be too
> much effort and error-prone.
> I'm okay with replacing the jdbc2 Makefile with a full-featured
> build.xml, but I do not like to maintain both. So if the majority here
> thinks that ant is better for jdbc2, and the refractions people do not
> have any objections, I'll create a build.xml.
> Maybe a compromise would be to have a minimal Makefile that's just
> enough to build the jars, and have a fully featured build.xml that
> includes the tests etc. Or vice-versa.
> Markus
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
