[postgis-devel] Changes in regression test framework
Nicolas Ribot nicky666 at gmail.com
Wed Dec 14 03:01:36 PST 2005
> -----8<-----------------------------------------------------------------
> Creating spatial db postgis_reg
>  PostgreSQL 8.0.0 on i686-pc-linux-gnu, compiled by GCC gcc (GCC) 3.4.3
>  Postgis 1.1.0CVS - 2005-12-13 23:21:22
>  GEOS 3.0.0-CAPI-1.0.1
> Running tests
>            regress: Ok.
>      regress_index: Ok.
>     lwgeom_regress: Ok.
>        regress_lrs: Ok.
>       regress_proj: Ok.
>        removepoint: Failed (diff /tmp/regress_removepoint_diff_24464)
>           setpoint: Ok.
>        regress_ogc: Ok.
>     regress_bdpoly: Ok.
> Run tests: 9
> Successful: 9
> Failed: 0
Is it normal to see 9 successful results. Shouldn't it be 8 + 1 failure ?
