[postgis-devel] release status
strk at refractions.net strk at refractions.net
Tue Feb 15 10:26:40 PST 2005
On Mon, Feb 14, 2005 at 08:09:44AM -0800, Paul Ramsey wrote:
> Before we bundle rc3 we need to get the qgis/mapserver connectivity
> stuff nailed down. Otherwise we are still not any closer to the final
> release.
Any news on the mapserver front ?
Is anybody able to produce a script that exploits the problem ?
(I personally can't reproduce the bug)
Could the problem be due to bogus upgrade procedure or it still
shows on a newly created database ?
--strk;
> P
> On Monday, February 14, 2005, at 01:43 AM, strk at refractions.net wrote:
> >It's almost one month since RC2 is out, and we have
> >a bounce of changes logged:
> >        - transform(): missing SRID bugfix, better error handling
> >        - jdbc2: small patches, box2d/3d tests, revised docs and
> >license.
> >        - jdbc2: bug fix and testcase in for pgjdbc 8.0 type
> >autoregistration
> >        - few changes in autoconf
> >        - reduced precision of box2d output.
> >        - some functions made IMMUTABLE from STABLE,
> >          for performance improvement
> >        - new performance tips chapter in manual
> >        - BUILDDATE extraction made more portable
> >        - fixed bogus 72 index bindings
> >        - prefixed DEBUG macros with PGIS_ to avoid clash with pgsql
> >one
> >        - fixes in probe_geometry_columns() to work with PG72 and
> >support
> >          multiple geometry columns in a single table
> >        - fixed spatial_ref_sys.sql to avoid vacuuming the whole
> >database.
> >        - jdbc2: Removed use of jdk1.4 only features to enable build
> >with
> >          older jdk releases.
> >        - jdbc2: Added support for building against pg72jdbc2.jar
> >        - documentation updates: pgsql72 requirement, lwpostgis.sql
> >        - memory alignment handling
> >The "segfaulting points" issue seems to be fixed (memory alignment
> >handling), but the following issues are still open:
> >	- mapserver connector weidness
> >	- spatial_ref_sys entries (compatibility ?)
> >I think the special handling of the SRID=-1 should wait until 1.1.0,
> >as getting 1.0.0 out is already taking too much time, so I removed
> >it from the list of "open issues" (it's a feature request).
> >If anyone has reports about mapserver connectivity or hints about
> >new proj4 entries please send them out. I'd tag and boundle RC3
> >this week.
> >--strk;
> >On Tue, Feb 08, 2005 at 09:11:29AM +0100, strk at refractions.net wrote:
> >>Update changes:
> >>license.
> >>autoregistration
> >>one
> >>support
> >>Updated open issues:
> >>        - segfaulting points
> >>        - mapserver connector weirdnesses
> >>	- spatial_ref_sys entries (incompatible between PROJ versions?)
> >>        - SRID=-1 special handling
> >>--strk;
> >>On Mon, Feb 07, 2005 at 01:25:41PM +0100, strk at refractions.net wrote:
> >>>12 days has gone since RC2.
> >>>This are changes so far:
> >>>license.
> >>>This are the open issues in order of importance:
> >>>It would be useful to have most informations about the bugs handy.
> >>>Paul, what about linking the bug tracker on the postgis web site ?
> >>>Is anyone experiencing the points bug on this list ?
> >>>--strk;
> >>>_______________________________________________
> >>>postgis-devel mailing list
> >>>postgis-devel at postgis.refractions.net
> >>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
>      Paul Ramsey
>      Refractions Research
>      Email: pramsey at refractions.net
>      Phone: (250) 885-0632
